Results 1 to 10 of 10
Thread: How to Remove Entire Cluster in a VT
    98 VT Commodore V6
    Mar 2005
    Briagolong
    Default How to Remove Entire Cluster in a VT
    I want to replace my Single Window Cluster with a 3 Window one, How do I remove the whole cluster and also is it just a matter plugging in the new cluster and getting a tech2 to recalibrate it? or does it require rewiring? thanks guys.
    Dan
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    The new cluster will just need recalibrating. You will need to remove the centre consul cover and the dash surround to remove the cluster.Do a search on how to remove the dash surround, it's been covered heaps of times.
    MY RIDE
    3.8L GT35 4runner/VK calais
    Dec 2006
    Nowra
    easy job mate did it myself about 8 months ago
    as said take the surround off and the cluster just unplugs
    take it to a holden dealer or someone with a tech 2 and they will set the dash for you
    98 VT Commodore V6
    Mar 2005
    Briagolong
    Thanks, I'll let you know how I go once I get the new cluster. Cheers guys, your help is appreciated!
    Dan
    98 VT Commodore V6
    Mar 2005
    Briagolong
    Hey, this is probably a stupid question, but when I put the new cluster in the odometre will be wrong. My car has done just on 140000, the new cluster is set at 200000. My question is are there any legal implications and am I able to set the new cluster to my original distance even though its not a brand new cluster from holden? Thanks.
    Dan
    Dec 2006
    Nowra
    Quote Originally Posted by nabed4t View Post
    Dan
    you can set the odo but you would have to take it to somewhere like vdo
    you cant do it with a tech 2 unless its under 100km
    98 VT Commodore V6
    Mar 2005
    Briagolong
    Dec 2006
    Nowra
    98 VT Commodore V6
    Mar 2005
    Briagolong
    Where they located? In Vic by any chance.
    do they have a web site?
    Would they be able to set my odometre to the original reading? thanks again man.
    Dan
    Dec 2006
    Nowra
    Dan
    you would be better off buying a cluster with lower km as it is expensive to get the odo reset
  1. WTB: VQ Statesman/Caprice or VN Calais, entire wiring harness
    By holdenrules in forum Swap / Wanted to Buy / Trade
    Last Post: 06-01-2007, 11:57 PM
  2. 25% Off Entire Range
    By Holden_Mechanic in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 19-12-2005, 08:02 PM
  3. 25% Off Entire Range
    By Holden_Mechanic in forum VY Holden Commodore (2002 - 2004)
    Last Post: 24-10-2005, 11:14 AM
  4. 25% Off Entire Range
    By Holden_Mechanic in forum General
    Last Post: 24-10-2005, 10:32 AM
  5. How to remove needles from VX instrument cluster???
    By 5N!P3R in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-09-2005, 05:03 AM
