Hi, will the VX diff be the same as my VT diff?
both non LSD n IRS and stuff...
also while im at it could i change the rear suspension to maybe fix that camber problem.
its from a 2001 VX pretty sure that would make it a s1, has that got a revised rear camber or is it not worth changing it?
Thanks
The rear suspension frame from a VX series 2 to VZ will help with the toe out / camber problems
The yoke is different from VT to VX on the diff.
^^^ Damn, beat me to it!! lol
Yeah, the VT has a metal yoke and the VX and VY have Rubber ones...
VT diff is smaller as well it is the same as any pre VT IRS diff
s1 is a bit bigger then VR-S etc and s2 is same size as vx+ but the yokes changed on vx+,all vt and lower use the same yokes
sorry for the confusion
so what we r saying here is that a series 2 vt will take later model diffs?
SUPERCHARGED VT Series 2 S pac
How hard is it to put a vx diff on a series 1 vt then.
Mounting points should be the same.
I'm running a VY diff in my VP (using a VR Statesman diff cradle)
Originally Posted by davway
Is that the same with a vx irs diff in a vt series one
my diff is defininetly on the way out but thats all i wanted to know, if and how to fit a vx diff to my VT S1. Il give it a go once i get time cos mines too loud to stand anymore.
So all i need to do is change diff (remove from axle ends in the middle, either side of the diff) and swap over the tailshaft (gearbox back) as well and all should be sweet ??
Ummmmm what was the question again ???¿¿¿
hi again. im half way thru changing the diff over now, with the tailshaft and i see how the yokes are different and iv realised the only way the remove it from the car is completely pulling it out from right inside the gearbox.
now im hoping the teeth and everything will be the same on these.
On a side note if anyone knows, what brand springs are dark grey ones?
Thanks
standard ones?
yeh both standard. so far iv almost got the newer diff out of the vx, took me a while to get to the bolts ontop of the diff....then i realised taking off the cradle lowers the diff...stupid things i do
hello mate , would a vy diff & cradle off a UTE fit into a vt SEDAN clubbie other than changeing the diff yoke / flange please . thx les
No, ute and wagon cradle is different to sedan cradle
hello jarryd & thanks . whats the difference please , can vy ute cradle be altered/ modified so complete cradle [diff axles etc } slot straight in, we ve just measured the width of cradles , from bolt mount to bolt mount and both are 1230mm .cant see any other probs other than diff/tailshaft & maybe rear of diff mount ? ? ? my vt 98 v8 rear is r/s & vy ute is very good .Thanks to all 4 further info if known cheers les
In regards to the first questions about a vx diff into a series 1 vt why wouldnt you just change the yoke???? stuff getting in there and swapping the tailshaft!
Cheers,
Ben
