Results 1 to 8 of 8
Thread: Vt Still Leaking Water.
    VT Calais II 6cyl
    Apr 2008
    Default Vt Still Leaking Water.
    Im hoping someone can help.
    I have a 99 VT II Calais. After it was purchased we had a heavy downpour. A few days later it smelt like arse! I removed the driver's floor mat and noticed a cut in the carpet running from under my brake pedal back to nearly my seat. I put my hand thru it and found a large puddle of water. The previous owner didn't let me in on this little problem.
    Anyway I have since replaced the windscreen due to a crack, this still hasn't fixed the problem.
    Can anyone shed some light on where the water would be coming in? Its a obviously a lot of water! I have tried the hose trick, to no avail...
    Anything at all would be helpful..
    Cheers all.
    Mick.
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Maybe the door seal leaking or a rubber grommet missing in the floor.
    MY RIDE
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Where does the climate control drain to on a VT. If you have a blocked drain in a VN = puddle on floor.
    Else can it get in via the fire wall someplace?
    and 3 Dangerous non ABS VN's
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by 88GreenVN View Post
    The drains a pretty much in the same place, so it's another possibility, but he said it happened after a heavy downpour.
    MY RIDE
    Vt Aclaim
    Aug 2007
    I had the same problem with my series one vt, It turned out to be the windscreen leaking, and yes it only happened in a heavy down poor, I only worked it out when driving the car down a hill one day in heavy rain and the water poored out from the headlining.
    Nissan Patrol GU II
    Apr 2008
    Adelaide, SOUTH AUSTRALIA
    Inside the door trim water freely travels down the glass, into the door shell and out through drain holes.
    Sometimes these drain holes get blocked or the plastic lining behind the trim can be incorrectly re-fit after a repair.
    Both can lead to water flowing over the scuff trim and onto the carpet.
    Better the Devil you know!
    benno145's Avatar
    benno145 is offline TUF38S
    VT 5sd
    Dec 2007
    Taree
    i had a leak behind the left hand side quarter panel. One of the seams had opened up which was letting water trickle in behind the cars computer. Wasnt a happy chappy when they sed it had caused about a 5cm round circle of rust. All fixed up now though. Still gotta get new carpet though
    Feb 2008
    Hey dude,
    I would firstly look at the aircon drain, this when blocked and leaking onto the floor pan does smell like arse.
    Smear some vasoline into the ends of the drain hose where it comes together like a little fanny, this will stop them sealing together again and blocking.
    Were you driving during during the downpour, if so the water may be coming in where seam sealant/bog may have cracked or come away from the seams on the firwwll and inner gaurds area.
  1. water leaking
    By johnny b in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-03-2008, 10:59 AM
  2. leaking water pump?
    By VNexecutive in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-02-2008, 08:00 PM
  3. Boot leaking water.
    By KLatham in forum VL Holden Commodore (1986 - 1988)
    Last Post: 15-01-2007, 09:26 AM
  4. A/C leaking water in cabin
    By Mr Ute in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-11-2006, 06:24 PM
  5. Leaking Water?
    By jabbavx in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-03-2006, 07:42 PM
