I have a 98' VT Executive Wagon V6 ecotech auto and the light on the cluster wont light up for the Power Button.I have replaced the power button switch and the tiny globe in the cluster,but it is still not lighting up.All parts where bought from holden.Any one know what it might be?I cant seem to find a fuse for the power button anywhere,so i guess it doesn't even have one.Thanks.![]()
BUMP.......![]()
is the power button actually working? Does it hold the gears for longer?
I haven't lost my mind, it's backed up on tape somewhere
Have you tried the bulb test function?" hold mode and up buttons then turn ignition to on. release buttons then press mode repeatedly until you get to bulb and buzzer and instrument test
You have got me stumped, I would suggest you find another cluster and try that.
Cheers,
DVS
Can anyone help me with this problem.![]()
As said b4 did u try the test warning light fuction using the mode button 2 see if it lights up then or not?
