hey, i bought a woodgrain fascia for my VT. Anyone know if this can be changed relatively easily? Any instructions would be appreciated!!
thanks!
yep theres 2 screws near your 12v charger under fuse cobver below steering wheel cover 2/3 above speed dials and i think 2 in glovebox and it should pop off
___________________________________
Car: 07 VE SSV 6LTR L98 A6
Metalic Silver
you'll need to remove the shifter surround first there's 2 screws either side of the accessory/charger thingy. after taking it off you'll c there's 2 screws that hold the compartment in place, they'll need to b removed as they also hold the dash surround. then it's all as baldric said, 2 above the cluster, 3 along the bottom of the surround under the fuse cover.
