Results 1 to 9 of 9
Thread: Interesting Ignition problem
    VT
    Apr 2008
    Default Interesting Ignition problem
    Hey All
    Since my last question proved to be successful, my poor commodore has had another mishap of late.
    I went to start it about a week ago, turned the key, all the lights went on but didnt turn overover. So when we went to turn it back off......the key turned back but everything stayed on! So we have had to disconnect the battery....
    I hope someone may have some insight to this little annoyance...before i have to tow it somewhere
    Emma and her broken CMDR
    Nissan Patrol GU II
    Apr 2008
    Adelaide, SOUTH AUSTRALIA
    Some times the ignition barrels snap off in the ignition switch...
    You describe it as tho the ignition lights are coming on, you turn the key to off, the ignition lights are still on. Is this correct?
    Better the Devil you know!
    VT
    Apr 2008
    VT
    Apr 2008
    what kinda work is needed to fix it do you think? Oh and thanks for your reply!
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    You will need to replace the ignition barrel. Quite simple actually because the barrel still turns. Remove the plastic surround, turn the key to "on", insert a pin in the hole on the side of the barrel and it will slide out. Install the new barrel by just pushing it in with the key in the "on" position.
    You can buy a new barrel and assemble it yourself, or you can take the old barrel and the new bits to someone to do it for you.
    Visit my Facebook page
    knowledge_is_power's Avatar
    knowledge_is_power is offline Quest for Cognition
    VT SII V6 A4
    Oct 2004
    Nth Brisbane
    Nissan Patrol GU II
    Apr 2008
    If this is the case you may need to remove the ignition switch from the end of the barrell if it contains a broken piece still.
    To refit the barrel you'll need to release the steering lock. I use a screw driver.
    Keep it in mind.
    VT
    Apr 2008
    luckily steering lock releases like normal....phew ...hah
    Got a barrel on its way so he goes nuthin .....
    Thanks for your help!
    wetwork65's Avatar
    wetwork65 is offline A wet business
    VY Berlina V8 & VZ Adventra LX8
    Mar 2006
    With the goblins in South West WA
    Mine dis exactly same thing on the same day!
    Replaced the barrel as he said - changed the brass pieces over from lock to lock (fiddly job) so I can use the old key and all is OK now.
    Took two days - my car was at a relatively remote work site in WA.
LinkBacks (?)
  1. 05-05-2008, 08:20 PM
  1. Ignition Problem
    By ELOSR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-05-2008, 01:24 PM
  2. VR Ignition Problem?
    By Radar in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-02-2008, 04:33 PM
  3. An interesting problem with my VT
    By Trei in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-01-2008, 06:08 AM
  4. ignition problem
    By blake0182 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-09-2007, 01:44 AM
  5. Ignition Problem
    By trombetta in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-12-2006, 10:15 AM
