Results 1 to 5 of 5
Thread: Ticking sound from behind dash
    Davidg Guest
    Default Ticking sound from behind dash
    The last week or two my commodore VT Berlina wagon has developed an annoying ticking sound that appears to be coming from behind the dashboard to the right of the driver as he is seated. It is like a tick tock, happens around every 5-6 seconds and although it sounds like a car indicator noise, it is not that as the indicators work fine and the noise continues separately even when the indicators are on. Everything appears to be working fine. Any ideas??
    Baldric is offline The BOSS
    VE GTS M6
    Dec 2003
    sounds like a faulty relay... take it to a holden person...
    ___________________________________
    Car: 07 VE SSV 6LTR L98 A6
    Metalic Silver
    VW J&S Supa Sport Dune Buggy
    Sep 2004
    4 seasons in 1 day
    Pull your wiper stalk towards yourself until it clicks, just like you would turn off your high beam with the indicator stalk.
    Sounds like your intermittant rear wiper relay is clicking, obviously you would have noticed that if your rear wiper was working. Sometimes the rear wiper is just not adjusted properly and it gets stuck underneath the rear window rubber, prolonged abuse of the wiper motor such as this can burn it out, so get your shifter out and re-adjust it if it isn't burnt out already. But it also could be a loose contact to the wiper motor, or it could have just bummed out on it's own.
    Let us know how you go.
    Toa
    Davidg Guest
    Hey Toa, you were spot on. I pulled the wiper stalk toward me and the noise stopped. Don't think the wiper is stuck so the motor has probably gone. Well spotted and thanks heaps.
    Sep 2004
    4 seasons in 1 day
    No problem.
  1. Ticking Sound From The Engine
    By gogoboygareth in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-05-2012, 09:26 AM
  2. Ticking sound
    By fullymetal in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-03-2007, 01:48 PM
  3. motor making ticking sound
    By TINYTIM in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-06-2006, 09:47 PM
  4. Ticking sound in motor!
    By mrVT in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-12-2005, 09:06 PM
  5. VT indicator ticking sound.
    By VIOLETANGO in forum Electrical Wiring / Questions
    Last Post: 08-06-2005, 04:48 PM
