Results 1 to 5 of 5
Thread: power steering whine
    Feb 2007
    Default power steering whine
    Hope someone can help?
    Recently I've noticed my VX calais (2001) has developed a high pitched whine when turning corners. It sounds power steering related. I've also noticed it only does this after the car has warmed up.
    Is this normal, or a sign that something's not right?
    Thanks
    VT Series 1 V6
    Jan 2008
    The obvious thing would be to check your steering fluid level. The reservoir bottle has markings for hot and cold levels. Apparently developing small leaks is quite common and the level can drop. Make sure you top up with the correct type of fluid.
    car
    Jul 2006
    greensy, melb
    yeh would be low fluid i'd say
    "A life lived in fear is a life half lived"
    Nissan Patrol GU II
    Apr 2008
    Adelaide, SOUTH AUSTRALIA
    Also check your fluid when the noise is present, assuming the level is okay, and look for air in the fluid. Could suggest a loose hose or air entry problem.
    Better the Devil you know!
    Feb 2007
    Quote Originally Posted by Kordorn View Post
    Thanks for your answers. I think the fluid levels are fine. However, whilst I was checking them, I did hear what appeared to be an leak.
  1. VH Power Steering..Trade For Manual Steering
    By vasrox in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 30-10-2008, 12:23 PM
  2. Power steering Vs. manual steering?
    By cruzncommo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-12-2007, 07:45 AM
  3. oil line from power steering to steering rack
    By onmy6 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-12-2007, 10:08 AM
  4. power steering pump...whine
    By immortality in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-10-2007, 07:10 PM
  5. VH Power Steering..Trade For Manual Steering
    By vasrox in forum Swap / Wanted to Buy / Trade
    Last Post: 28-01-2007, 02:29 PM
