Results 1 to 4 of 4
Thread: Brake caliper movement
    WH II Statesman GEN III
    Jun 2005
    Dusty Dubbo
    Default Brake caliper movement
    hey all, have been hearing some funny noises from the front of my VT lately, thought I'd try and find where it is coming from, anyway had no luck finding it.
    thought it may have been the link rod bushes, but they seem fine. any way I noticed there seemed to be a lot of movement in the guide pins on the front calipers is this normal ? the mounting bolts to the strut tower are tight and no movement there, but where the guide pins slide in and out there is a lot of sideways movement, i'd say between 3 and 5 mm of movement, is this normal or is it possible the pins are worn. both sides are the same.
    thanks for your time
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Normal, they will move a bit. 3-5mm is nothing really.
    Re the noises, check the radius rod bushes and the strut tops.
    Visit my Facebook page
    knowledge_is_power's Avatar
    knowledge_is_power is offline Quest for Cognition
    VT SII V6 A4
    Oct 2004
    Nth Brisbane
    I suggest the same as above ^^^
    Something else it can be is cheap front pads, I've seen instances where the backing plate was a few milimetres out and rattled.
    Jezz
    Jun 2005
    Dusty Dubbo
    thanks, will have another look today, I am going to replace the link rods and bushes, so while down there will have a look at all the other bushes etc.
    brake pads seem to be firmly in place.
  1. movement in camshaft??
    By GMBanisher in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-10-2008, 06:12 PM
  2. Brake caliper types
    By Longman in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-02-2008, 12:59 AM
  3. brake caliper question on my VT
    By werdy666 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-04-2007, 07:53 PM
  4. Transmission movement
    By Sebastian in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-03-2006, 11:51 PM
  5. Brake Caliper Cover kit??
    By akcim13 in forum General
    Last Post: 09-03-2006, 04:30 PM
