Hi guys, my left indicator is flasher alot faster then normal, do i need a new flasher unit or could it be something else? n if so does any1 have a rough idea of wat ones worth?
Check to make sure both front and rear indicators are going... if either are blown, it'll flash a lot faster.. replace the stuffed bulb..
What happens when the light just stays illuminated and no ticking noise, it is startign to happen to mine every noe and then, like it freezes, lite on panel is on, but no noise, no flashing, i not even sure if it working outside.
Thanx for the help, got a new flasher unit n shes as good as new.
If you dont mind me asking, where and how much is the flasher unit ?
I had this same problem recently, the right indicator was working intermittently, then all of a sudden I put the indicator on and it went fast, only the left one was working. Upon removing right indicator I find that the orange coating on the bulb is cracked away and the globe is blown. Had a sparey in the shed, so I replaced it and all is working good.
If on the right side (Drivers side) you will need to loosen off battery clamping piece to get access to the bulb and holder.
Cheers,
VT97Calais
