Results 1 to 7 of 7
Thread: Troublesome smoke From Climate Control?
    VT Berlina Wagon
    May 2008
    Default Troublesome smoke From Climate Control?
    Hi all,
    Hoping someone can help.
    My climate control starts blowing a nasty smelling smoke from the vents after a while with the aircon on, I don't use heater, always set on 20 degrees.
    I don't think it is the heater core, there is no fluid loss, no wet patches in the footwells or close, and no condensation from steam inside the car.
    I gave up finding the problem, switched off the climate control, and resorted to 4 window aircon .
    However, now that it is cooling down a bit, (and still with the climate control firmly switched off) after 5 minutes of driving, the same smoke now comes from behind the dash, (not the vents), mostly up from behind and under the steering column. It has been happening for months now, so I don't think the car is about to catch fire, but I'm starting to think it needs fixing. I am worried it is affecting my thraot, I am constantly having a sore throat. I have rung quite a few mechanics / aircon people, all quote me a thousand bucks to have a look, due to the need to strip the whole dash.
    Hoping someon in the know might have heard of this problem before.
    Thanks in advance.
    Last edited by stufishing; 14-05-2008 at 04:04 PM. Reason: Extra information / symptoms
    vs commodore sedan
    Jul 2005
    vt commodore wagon
    Nov 2007
    I had a similar problem and I fixed it by lifting the front plenum chamber on the passenger side and put my fingers in to find the air flow flap/door .I pushed down and the flap/door opened .problem solved .Worth having a look.
    VT Berlina Wagon
    May 2008
    Thanks mate, sorry for the stupid question, but what is the plenum chamber on the passenger side?
    vt commodore wagon
    Nov 2007
    The plenum is in between windscreen and bonnet . You may need to remove the wiper .
    VT Berlina Wagon
    May 2008
    vt commodore wagon
    Nov 2007
    I take it that the problem is now solved.
LinkBacks (?)
  1. 28-05-2008, 07:51 PM
  1. Climate Control
    By AL'sVY in forum Electrical Wiring / Questions
    Last Post: 27-08-2007, 11:10 AM
  2. Climate Control
    By raZel in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-09-2006, 07:59 AM
  3. Cruise Control and Climate Control?
    By Mr_mystikal in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-04-2006, 06:29 PM
  4. Climate Control
    By Haze in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-03-2006, 06:46 PM
  5. Vx Climate Control
    By MR CHEV 5.7 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-05-2005, 10:12 PM
