Results 1 to 3 of 3
Thread: gen 3 auto ?????
    vn 5 litre
    Nov 2007
    Default gen 3 auto ?????
    hey all just had to have my vt ss gearbox rebuilt got my car back today the bloke at the transmission place said i should take it to holden and have them reset my computer just wondering if this is really neccessary or is there a way i can do it myself. car drives great so just dont see the point
    dijm8's Avatar
    dijm8 is offline What You Looking At
    VZ SS LS3
    Jun 2006
    wrong section buddy, u want this in the vt/vx section not the my ride... if its drivin fine though i wudnt think so... im sure the other guys will know for sure
    3.8L GT35 4runner/VK calais
    Dec 2006
    Nowra
    Quote Originally Posted by Gav1802 View Post
    VT-VY Computer Reset and Idle Relearn Procedure
    WARNING: You can damage your PCM if the ignition isn’t off when its (engine fuse) connected or disconnected.
    The engine temp must be above 80degrees before you reset your ECU.
    Read through this manual before you attempt to do it and have the fuse located ready to remove before you start.
    To use the digital temp gauge to get the engine above 80degrees (aim for about 90-95 for best results) follow these instructions: with the car off, hold down the MODE and UP buttons on your trip computer. Now start the car (while holding the buttons). Scroll through the functions using MODE until you reach TEMP. Leave it here and wait for it to get to about 90degrees.
    1. Now that the engine temp is above 80degrees, turn off the car.
    2. Remove the PCM fuse. It’s under the bonnet, in the engine compartment fuse/relay panel (the one just behind the battery). There should be a list of the fuses and their names on the back of the cover. Find: F31-the ENG. CONT/BCM fuse. It’s a Red 10amp fuse.
    3. Once located, remove fuse, turn on, wait 20 secs (or the beep) and turn off.
    4. Replace the fuse.
    5. Turn ignition on (don’t start it), pump pedal full range up and down 5 times, turn off, turn on and start it.
  1. VT V6 auto not always using 4th
    By andrewb in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-01-2008, 01:54 PM
  2. need auto help
    By WILD VR CLUBBY in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-03-2006, 11:02 PM
  3. VN auto no 2nd
    By GH05T in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-12-2005, 01:08 PM
  4. want to swap a new not reco VS 5L auto for a VN 5L auto
    By troy7979 in forum Swap / Wanted to Buy / Trade
    Last Post: 26-08-2005, 12:01 AM
  5. auto help
    By nu2com in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-05-2005, 08:56 PM
