Results 1 to 7 of 7
Thread: l67 via manual box
    benno145's Avatar
    benno145 is offline TUF38S
    VT 5sd
    Dec 2007
    Taree
    Default l67 via manual box
    Just a couple questions guys.
    Well the motor in my vt v6 is starting to get a bit tired and instead of re-building it i thought about buying a l67 motor and throwing it in. Now, will my getrag 5spd bolt up to it and what would i do about the computer. Reprogram it ??? (dont know much about the electrical side of things)
    Caus i thought they were only released in autos, or am i mistaken.
    Thanks Ben.
    nicko's Avatar
    nicko is offline Carbon Positive - DO IT!!
    75 cruiser ute
    Sep 2007
    sa
    getrag will 'bolt' up but u will need a different computer. not sure what? also the getrag is a **** box mate it will die behind you l67. go for a t5 or the 6spd behind the gen 3
    no longer a hoon by association - the commodore is gone
    nicko's Avatar
    75 cruiser ute
    Sep 2007
    sa
    i have a 5spd getrag and i wouldnt trust it as far as i could throw it, and its only got 90,000kms on it
    benno145's Avatar
    VT 5sd
    Dec 2007
    Taree
    Yeh mines not the best hey
    So the t56 will bolt up to it from a ls1. Will my pedal box need to be replaced aswell or just the flywheel,clutch etc. Yeh stumped bout the computer. Might need to go aftermarket.
    Just was contemplating the idea. Will prob just go a raptor kit. Must admit very good bang 4 ur buck. Will most likely rebuild the old ecotec first.
    VX S SuperCharged
    May 2008
    Not to ressurect a dead thread....
    I have a VX S S/C, wanting to convert to manual. Everyone keeps chucking info at me left right and centre that doesn't make a lot of sense, wanted someone to clarify.
    I want to go for a T5 or T56 whichever comes easiest, most likely a T5.
    I've been told that in order to convert to manual I need a different wiring loom. As I understand it, the Engine and Gearbox loom are part of eachother. 1st problem: the Supercharged engine would no doubt have extra wiring compared to it's N/A Cousin, yes? Also, the L67 didn't come in a manual option, is that right? So, there would be no loom in existence to cope with this conversion, is that a fair statement?
    Next, I've been told I need to change the computer over to suit a manual. Ok, again, wouldn't this computer need the ignition mapping and whatnot of the L67? which again brings me to the 'no manual question' of this engine.
    What I have in mind is to drop a T5 in with appropriate accessories, connect the wiring for the reverse light detent switch and forget about the rest of the auto wiring, and then have someone change the programming in the computer to tell it it's not auto anymore.
    I know this sounds overly simplistic, but can someone verify that this is possible? Can I change the programming in the VX S/C Ecu to make it manual?
    nicko's Avatar
    75 cruiser ute
    Sep 2007
    sa
    hey mate,
    have a look at this site and send them an email or give them a call. They will be able to answer any questions.
    Mal Wood Automotive
    cheers,
    Nick
    GTP 85's Avatar
    GTP 85 is offline 291 hp @ the wheels
    VS track car & VS SSenator
    Aug 2006
    Adelaide, near the bay
    you can get the t5 to work behind the super 6. Basically, as you have said it, an auto ecu will still be able to cover the engine side of things. It just needs to be tuned so that knows there isnt an auto trans there anymore. True that the engine and trans are both operated by the ecu, but auto trans functions can be disabled.
    My VS ecotec was converted to manual, and it still runs the auto ecu with a manual memcal. the manual memcal cancels out everything to do with auto trans errors. Then some simple wiring mods were done to get the speedo working. So it is doable.. everyone was telling me that i DEFINITELY needed manual ecu and loom.. not so..
    I know that my example was that of a VS ecotec, but VT (you would suppose) wouldnt be much different!?
    i'm sure someone else on here has definitely done it with a L67 and can help you further. Or else maybe post up on SC??
    hope i have helped a little...
    Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
    GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
    Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
  1. 4spd manual to 5spd manual
    By Orloxsis in forum General Discussion
    Last Post: 11-04-2008, 08:57 PM
  2. WTB: Manual conversion or wrecked vn-vr manual
    By na3point8 in forum Parts And Other Items For Sale
    Last Post: 13-03-2007, 10:22 PM
  3. FS: VH Workshop manual and Owners manual
    By pro_gmh in forum Parts And Other Items For Sale
    Last Post: 27-09-2006, 10:36 PM
  4. difference between v6 manual - v8 manual
    By VN-88 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-03-2006, 08:46 PM
  5. WTT: camira service manual for a VP sevice manual
    By sparra_gump in forum Swap / Wanted to Buy / Trade
    Last Post: 02-12-2005, 01:18 PM
