Results 1 to 5 of 5
Thread: Keyless Entry Agian
    98 VT S-Pack
    Oct 2007
    Question Keyless Entry Agian
    Allo All,
    I'm trying to work out if my keyless entry is not working because of the KEY or the car's reciever unit.
    The keyless entry stopped working a couple of yrs ago but I can still use the same key to start the car.
    Re Battery? Here's the question; Does the car key battery die in levels? IE not strong enough to send signals for keyless entry but still strong enough to activate when put in ignition? I assume the key still needs some power to bypass the ignitions built in immobilizer.
    Help? Will a new key magically revive my keyless entry?
    David Maifredi
    dmaifred@ispconnect.com.au
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    I think a new key head will solve your problem. Some people successfully pull the head apart and replace the battery which is soldered in.
    MY RIDE
    Doctor Bob's Avatar
    Doctor Bob is offline Grandpa
    VT V6 Exec & VN V6 Exec
    May 2004
    Mornington Peninsula
    the battery in the key only affects the RF section of the key, the circuit that is read when in the barrel is a passive circuit and can continue to work for ages after the battery has died.
    get a new key & see what happens.
    98 VT S-Pack
    Oct 2007
    Alright, I broke down and paid the $106 from Holden. All the remote locks work great agian. (I hadn't had them working in 3 years).
    I kept the old key head and might give the battery swap trick a go on that one. The Holden parts guy reckons it is still programmed to the correct code.
    -Davo-
    98 VT S-Pack
    Oct 2007
    Smile
    -Davo-
  1. Keyless Entry
    By judd in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-09-2008, 09:08 PM
  2. keyless entry
    By mason_luke in forum Electrical Wiring / Questions
    Last Post: 05-11-2007, 11:58 AM
  3. Keyless Entry?
    By Keesh in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-11-2006, 11:41 PM
  4. Keyless Entry
    By SSbeast in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-09-2006, 03:01 AM
  5. Keyless Entry
    By blitzpc in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-09-2005, 07:36 PM
Tags for this Thread
