HEy there all... I have a VT belina and about to lower, and rplace the v6 for the v8, my questionis Im wondering which way to go regarding wheels size, im thinking either 19 or 20 inch, is there any problem that anyone knows about fitting this size wheels..
cheer
JOhn![]()
roll the gaurds and get a camber kit. Gaurds rolled - $50 a gaurd, camber kit - $400
no longer a hoon by association - the commodore is gone
Roll the fronts, don't bother with the rears, as no-one ever buys rims that sit anywhere near Commodore rear guards.
Even with camber kits, you wont rub the guards.
cool, so is there any need to replace the front struts for coil over suspension, Ive heard all sortso f storys regarding the 20 's wont fir with the standard struts.
cheers
as long as you get the correct profile tyre you will be fine, have a look at digm8's VX he has 20's
Coilovers will give you LESS clearance, as the bottom spring perch is much further down than the standard strut.
is rolling of the guards necessary only if im lowering my vt?
