steering lock jammed on!!!!!
vxchick
Can someone tell me how to the get the steering lock off on my vx wagon. It is on full lock and i cant turn the key.:bang::cry::bow:
nicko
Carbon Positive - DO IT!!
sa
75 cruiser ute
you may have tried this but, wiggle the streering wheel from side to side while trying to turn the key.
Tom_1569
Ecotech Power
Gippsland - VIC
'14 SR5 Pusslux
As Nicko says, even though its locked, you can move the wheel a little bit each way. Move it one one and wiggle it, its like taking the pressure off the lock, then turn the key. The VT's VX's seem to really bad for this.
vxchick
Tried this for about an hour but wont budge seems to be really on full lock and wont budge. Is there a manual way i could get it to unlock?
nicko
sa
75 cruiser ute
try jacking the front of the car up to take the weight off the wheel. How much play is in the wheel when its locked on. its should have about 5-10mm of play, if its anything less take the weight off the front wheels and try
vxchick
thanks nicko ill try it cause i have no play in the wheels at all at the moment
nicko
sa
75 cruiser ute
yeh that might be it then. if mine is lock on and i dont wiggle it (or cant) then it wont unlock, but it just needs that few mm of play to get it to unlock.
goodluck with it though, that would have to be one of the most annoying things to happen. so simple but still causes dramas
Tom_1569
Ecotech Power
Gippsland - VIC
'14 SR5 Pusslux
Can you wiggle it at all? sometimes the require a fair bit pf pressure, so try both hands trying to wiggle it either way. If you can wiggle it, then id say its really jammed or you have really flat tyres, i noticed when we had a flat it was so hard to get the lock off.
[EDIT] Nicko has the faster fingers lol, follow his advice if it isnt moving, [/EDIT]
vxchick
thanks tom just waiting for brothers other jack to try to jack it up, i cant wiggle the wheel at all it sems to be really stuck!!!!!!!!!!!but no flat tyres though.
adam69
Banned
VT Clubby
Turn the wheel in the same direction as the lock as hard as you can then try.It wont work if you are trying to go the other way.
