Results 1 to 3 of 3
Thread: gremlin
    VT v6 Acclaim
    Apr 2008
    Default gremlin
    Hi guys, Teddy her with a blooody doussy!!
    I have a vt series 1 commodore and the piece of #$%^& is running like a proverbal dog at idle and when we are driving at a idle speed.
    I have recently had to do the head as the missus blew it and then i had all the nightmares you could not beleive.
    So where i am now is.
    No 4 cylinder was the problem. ie it had the water in when it blew.
    Now !! I have changed the heater core , radiator thermostat, head gasket regrind set , reshaved the heads (no cracks seen by the man), new leads, new sparks
    Not leaking water, or smoking, no bubbles in radiatior.
    I pull the no 4 injector off at idle and it makes no difference until you rev the car and then it does. So i though ok it maybe a dead injector so i painly swapped it with another and its the still the same . I checked the resisitance before i did and it was in the normal range . I have compression and spark (bloody heaps). I tried a coil and it made no differnce!!!.
    I also puled the tappet cover off and had a look and they are working visualy any way .
    error code is 12!!!!.
    Any ideas as I am ready to burn this sucker!!!!!
    Teddy
    s_ikari2015's Avatar
    s_ikari2015 is offline Fun IS easier with an 8
    '02 Monaro V2 CV8 6m
    Nov 2007
    Australia
    idea #1... get a jerry can full of petrol.......
    idea #2... could be a blocked fuel rail where it branches for No. 4 injector.
    Don't know what the codes are, unfortunately.
    I haven't lost my mind, it's backed up on tape somewhere
    Noy
    Noy is offline
    VN SS 5.0
    Oct 2006
    Code 12 = no errors
    Im pritty sure anyway
LinkBacks (?)
  1. 31-05-2008, 02:18 PM
  1. vt eleectrical gremlin
    By jimmig81 in forum VB - VC - VH - VK
    Last Post: 06-11-2007, 08:06 AM
  2. vt electrical gremlin
    By jimmig81 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-11-2007, 07:50 AM
  3. That bastard back speaker gremlin
    By VTPREDATOR in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 31-01-2006, 09:53 AM
  4. HELP! VS Berlina climate & horn gremlin
    By simc in forum Electrical Wiring / Questions
    Last Post: 01-12-2005, 12:27 PM
  5. Bambooled by gremlin
    By kenemack in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-06-2005, 11:52 AM
