Results 1 to 6 of 6
Thread: Vt Lsd Diff
    VR EXEC WAGON
    Oct 2007
    BORONIA
    Default Vt Lsd Diff
    Hi all was just wondering if anyone could tell me if a v8 lsd diff is able to go into a stocky vt ? if so what are the better ones to go for ? and is there any real hassles with changing it over ? any help would be greatly appreciated
    knowledge_is_power's Avatar
    knowledge_is_power is offline Quest for Cognition
    VT SII V6 A4
    Oct 2004
    Nth Brisbane
    Yes you can replace the diff with a V8 LSD as long as it is from a VT. The VX diff's are different where the tail shaft attaches to the yoke of the diff.
    No real hassels to change it over. The bolts will be very tight because of the thread lock that has been used to secure them. And a little care needs to be take when installing the LSD for alignment as it will affect the rear alignment for the wheels and can cause steering and tyre wear anomalys.
    Jezz
    VR EXEC WAGON
    Oct 2007
    BORONIA
    ok cool thanks alot for that, would anyone now the standard diff ratio for a vt ?
    nicko's Avatar
    nicko is offline Carbon Positive - DO IT!!
    75 cruiser ute
    Sep 2007
    sa
    3.08:1 standard vt diff.
    no longer a hoon by association - the commodore is gone
    VTSS
    Jun 2008
    ballarat
    Kikki's Avatar
    Kikki is offline WA Cruise Moderator
    08 VE SSV Sportswagon & 98 VT Berlina Wagon
    Aug 2007
    Eaton, WA
    remove the big bolt at the bottom of the hat
  1. V8 Diff vs 6cyl Diff
    By RSO in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-04-2009, 09:45 PM
  2. diff making a noise / replacing diff
    By yipya in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-12-2008, 11:30 PM
  3. Swap VZ diff for VE diff?
    By georgehifi in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 13-03-2008, 06:31 PM
  4. Putting in new diff oil and replacing diff gasket ?
    By gemini in forum VL Holden Commodore (1986 - 1988)
    Last Post: 07-10-2007, 05:22 PM
  5. Diff Oil?
    By mudslngr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-10-2005, 06:16 PM
