Results 1 to 12 of 12
Thread: Supercharger belt squeal
    VT S 'Charged 6
    May 2008
    Murray NSW
    Default Supercharger belt squeal
    I recently had the charger belt replaced on my VT S, no probs with it prior except it was fairly worn/perished. The new belt now squeals. Not all the time, but more often than not. And I cant pick when it will happen - sometimes it does it when the engine's cold, warm, at low speed, idle, during acceleration and at highway speeds.
    Its pretty embarrassing!
    I've had it back the the mechanic re this prob three times already - the final time resulting in another new belt, but to no avail.
    Any ideas??
    VN_Luke's Avatar
    VN_Luke is offline ƃuoɹʍ ʇsnɾ sı sıɥʇ
    VT, RB30EST VN
    Mar 2005
    de-grease all your pulley surfaces, can also try that 'belt grip' spray....
    If it were my car, i'd say it's likely that the auto-tensioner(s) not keeping correct tension, allowing the belt to slip. (presuming the super 6 has a spring loaded tensioner like the rest of em)
    Shounak's Avatar
    Shounak is offline The Kicking Horse
    VX Executive S2 + XF Panel Van Project
    Apr 2005
    Put some Penrite Extreme Pressure grease all over the belt pulley and tighten it a bit.
    You could also use Silicon Spray, but the grease comes in handy for a lot of car things.
    Shounak
    Always Right
    My Ride
    Jun 2005
    i need details on that belt grip stuff. mine squeels too. i dont think my pulley has enough grip because of the material its made from. when im up around 4000+ revs and then let the revs drop, the belt must not be able to catch the pulley and i get a real bad squeel
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    VT S 'Charged 6
    May 2008
    Murray NSW
    Thanks for your quick replies! I'm pretty sure that Belt Grip's been tried in this case, so maybe there is an issue with the pulley and/or tensioner. Will investigate...
    KRUPTD is offline VN BT1 5L
    VN BT1 5L,5spd,LSD
    May 2007
    Griffith, N.S.W
    make sure it is the supercharger belt making the noise.remove the supercharger belt and start the engine if the noise is still there it must be the engine drive belt or visa versa.also check the idler pulley's for noises,make sure they can spin freely.had come across this on a vx supercharged commie and it had a seized pulley.
    (KRUPTOR)VN BT1 5L TTB's,MANUAL,LSD
    VX II SS Ex Chaser V8
    Jul 2005
    My VX SS V8 has belt noise as well, you can't get your hands anywhere near them while to motor is running. On my VR V6 I rub chalk in the groves of the timing belt and it goes quiet, I think with age the belt wears and the pullys get a shiney glaze and this causes the squeal The chalk takes off that glaze. Watch you hands if your near a pulley as the chalk will grip and try and pull your hand into it, OUCH !!!!!
    pablo is offline Donating member
    Was a 1997 vt v6 wagon
    May 2006
    Surely a quick squirt of 'Belt Slip' or similar product would stop the slip. Run a thin zig zag bead of honey around the belt, that'll get it to grip quick smart!
    Nov 2007
    This is a Very common occurance for me. Almost everytime I have replaced a supercharger blet it will squeel with the new belt. I get a wire brush and clean all the grooves of the pulleys carefully and the noise goes away.
    VT S 'Charged 6
    May 2008
    Murray NSW
    Most of the above 'easy fixes' were tried and failed, eg wire brush, belt grip, chalk - nothing helped! In the end it turned out the charger bearings were shot and have now been replaced - and the pulley too. Good as new!!
    For some reason it is always the worst case senario on my VT....
    2000 VX Calais 3.8L Supercharged
    Jul 2006
    haha the exact same thing happened to me about 2 weeks ago, i let it go for a few days, decided to get a new belt. but after a bit of snooping around some people were telling me its the snout bearings if it squeeks on startup for a few mins then goes away when its warmed up a bit. also u can hear it if u get a stiff screwdriver and put it close up to the pulley on the snout
    i still havent fixxed it yet but i was just planning on upgrading to a YT 10psi snout anyway so now its just giving me an excuse bahahaha
    VTII Calais S/C
    Jan 2006
    Brisbane (South)
    I replaced my belt two weeks ago, and after a week it started squealing as well.
    I took it into the shop (getting some other work done) and my mechanic pointed out the wear on the pulley itself.
    Turns out the pulleys have a tendency to wear out if you have a tendency to accelerate somewhat enthusiastically.
    Either way I got preliminary quotes on a 10psi pulley from Yella Terra and I am looking at around $150 - $200 installed (labour is being soaked up with my other work though).
    Not suggesting you spend the money without getting it checked, but maybe have a good look at it and get you mechanic to check as well.
    Might be time for an upgrade
    I'm getting official quotes on the pulley and the package deals (EEPROM, pulley etc) on Monday.
    PM me if interested.
    cheers .. Az.
    AZMAN the RADMAN
  1. CRS supercharger Belt 6pk3055
    By VSteve in forum Parts And Other Items For Sale
    Last Post: 17-05-2008, 07:56 PM
  2. YT-4081 5L Supercharger Gilmer Belt
    By PREDATR in forum Yella Terra
    Last Post: 05-03-2008, 07:23 AM
  3. supercharger belt
    By badaz in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 31-12-2007, 12:33 PM
  4. Supercharger belt fell off. What the?!?!
    By Scooter79 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-02-2007, 02:59 PM
  5. CRS Supercharger small pulley belt
    By commodore in forum V6 Development And Modification
    Last Post: 27-01-2006, 09:41 AM
