Results 1 to 13 of 13
Thread: car shudders while driving and taking off
    VT Executive series 2
    Nov 2007
    Default car shudders while driving and taking off
    I just had my car serviced and tuned yesterday and my car was running fine, got it back and now whenever i drive or accelerate my car just shudders and kind of pulls back what is the cause of this? the only time it happened previously was when i start the car to take off but now its always doing it. The mechanic said it was the injectors but like i said its gotten worse ever since i got my car back.
    thanks
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    did they repace the spark plugs and leads, does the engine sound like its missing at idle?
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    2001 VX Commodore S1
    Mar 2004
    Brisbane / Springwood
    I just recently had this happen to me.!
    I just had a 130,000K service, but also my Engine Mounts too ...
    Got the car back, & soon afterwards, I get this spluttering on acceleration.??
    I thought it might have be Dirty Fuel, or my Rear Exhaust, because it needed it.!!
    Turns out 4 me ... I thought I'd check the Spark-Plug Leads, Top & Bottom.!!
    2 of them weren't *clicked in properly*, and another 2 weren't quite in either.?? - Now all is sweet.!! - Lucky Me.!!
    adamc11 is offline Donating Member
    VY SS
    Feb 2008
    E. & W. Suburbs Melbourne
    Don't wish to hijack this thread... but is it possible to run your car on fewer cylinders by unplugging spark plug leads or removing spark plugs?... is it safe?
    VX Calais 01 3.8lt Ecotec
    Jul 2006
    hehe you been watching that new ad of the 4WD that can go from 8 cylinders to 4....
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by adamc11 View Post
    No you can't. Just unplug one lead and it will run like a bag of poo.
    The new cars that are able to run on less cylinders are designed for that, commodores aren't.
    MY RIDE
    Nov 2007
    yeh they did replace the leads...im not much of a car expert but where abouts should i look to see where the leads/plugs are
    Cursed CX8 is offline Banned
    VY Adventra
    Feb 2008
    Walking distance to FG meets
    im assuming ur car is a v6, in that case there is a section on the top of the engine at the right. The coils/DFI module. Its black and has 3 raised up sections; these are the coils, on top of these there should be 6 leads (high tension cables/spark leads) with 3 running to each side of the engine. Where they connect into the engine/heads are the spark plugs
    Nov 2007
    tryed that i thought it was that so i unplugged them and then plugged them in pushed them real hard but still no luck... what else could it be? also now whenever i put the indercator on it doesnt flash it just stays on how do i go about fixing that?
    AttaBoy is offline WTF?!?!
    VS Acclaim V6
    May 2005
    Man... they really fcuk up your car. Take it back and tell them the problem.
    Jesterarts's Avatar
    Jesterarts is offline Your freedom ends where mine begins
    2005 HSV Z R8 Manual
    Nov 2005
    Mornington, VIC
    I'm really hoping your taking the p*ss...
    It would be like having 2 cylinders miss firing... the car would be undrivable, the engine wouldn't even run I don't think...
    Tom_1569's Avatar
    Tom_1569 is offline Ecotech Power
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    Quote Originally Posted by Jesterarts View Post
    Nah it would run, ive had cars run down to 1 cylinder, but 6's generally wont get down that low, but it will go to 2 cylinders at idle. BUT you will not save petrol, the car is still pumping fuel in the bore for it to combust, and the other cylinders have to work hard to make the same power, so you would infact use more petrol.
    My paddock bomb blew a head gasket, and had very low compression on cylinders 1 & 2 (its a 3 cyl engine) and it started using alot more petrol after that. On 1 cylinder it only got about 550k's a tank, lol a 34 litre tank.
    Quote Originally Posted by alien View Post
    I have been hit by oil badly once while in Army uniform on a massive roundabout that doesn't exist anymore. Spun 180 degrees to face oncoming traffic.
    VT Series 1 V6
    Jan 2008
    Take it back to the mechanics and get it fixed, and don't pay extra. It's most likely they've cracked a spark plug or a lead, the leads are tricky to get on. Either way, if it wasn't doing it when you dropped it off, then it's likely something they've done.
    Let us know what happens.
  1. taking a engine out
    By homer simpson in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-07-2009, 11:47 AM
  2. Stupid Violent Shudders
    By fentos in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 05-10-2006, 12:01 PM
  3. Taking on a Council!
    By tdog in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-05-2006, 08:00 PM
  4. VT Brake Shudders
    By Secki in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-04-2005, 03:06 AM
  5. Got the shudders
    By ralph in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-11-2004, 09:31 PM
