Results 1 to 9 of 9
Thread: Wheel Bearings, easy or hard to renew
    Berlina VT
    Oct 2007
    Default Wheel Bearings, easy or hard to renew
    Hi Guys,
    Ive got an annoying drone/whine coming from one of my front wheels. Im pretty well covinced that its the wheel bearing that has worn, what id like to know is if its a DIY job. I know my way around a a cars workings, im by no means an expert but im pretty handy. Is it best left to the experts or should i give it a go.
    cheers
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    You have to replace the whole hub assembly, you can't change the bearings. I don't think it's an overly difficult job although I've never replaced one. The hub assemblies can be expensive, depending on where you get it, so you would want to be sure it needs replacing.
    Some tyres can be loud and sound a bit like a worn wheel bearing.
    MY RIDE
    Fr3ak+--'s Avatar
    Fr3ak+-- is offline Closed On Monday
    Vt Exec 5 Speed
    Jul 2006
    Kingswood, Nsw
    VP Exec
    Jun 2005
    It is an easy job (but screwing it up could be expensive or get someone hurt.)
    Wheel off, 19mm socket and 1/2" bar; caliper off, 19mm socket and 1/2" ratchet.
    Disc off, soft face hammer - maybe.
    Hub/bearing off, 8mm? Allen key - they will have thread locking compound on them from memory and be fairly hard to undo.
    It's been a while since I've done one but I don't think you have to disconnect the steering tie rod end or remove a brake disc shield. There's a bit more if you do.
    I would use Loctite 242 when putting the hub bolts back in too.
    Tom_1569's Avatar
    Tom_1569 is offline Ecotech Power
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    Quote Originally Posted by Fr3ak+-- View Post
    yeah they are like 300-400 a side!
    Im guessing you replace both sides just to be safe lol.
    I always like to replace both sides at once, and is now just common practice, but not at that price, you'd be mad.
    Quote Originally Posted by alien View Post
    I have been hit by oil badly once while in Army uniform on a massive roundabout that doesn't exist anymore. Spun 180 degrees to face oncoming traffic.
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    As other posts have indicated, if it's just noise you are worried about it's more than likely to be coming from your tyres. To test, jack up the front wheels and try moving the road wheel by alternately moving them from top to bottom and from left to right (have the steering locked). If the hub bearings are worn or faulty you should be able to hear/feel some clunking. Replacement hubs/bearings are available on eBay for less than half the price of the genuine items but longevity is yet to be tested.
    RufusŪ's Avatar
    RufusŪ is offline I Jizzed in my pants
    VR S1 S Pack, VX S2 Acclaim Wagoon
    Apr 2005
    The Marsh, Vic
    you sure thats per side? I was recently quoted $188 each for the VX
    Signage, Splash Backs and Display Systems
    "No, I'm not a pessimist. At some point the world shits on everybody. Pretending it ain't shit makes you an idiot, not an optimist."
    2007 SVZ Wagon
    Aug 2007
    Murray Bridge
    Quote Originally Posted by Tom_1569 View Post
    Always pays to do both sides at the same time. Keeps everything in 'harmony' and 'sync' and will give you confidence in the knowledge that neither side should fail and you lose a wheel - probably with disastrous results (and expensive too). Never pays to compromise on vehicle safety and roadworthiness.
    BOGANV8's Avatar
    BOGANV8 is offline I gotta V8 whoot whoot
    VX 02 SS LS1
    Dec 2005
    Armidale
    The best way to check if it the bearing as mine did the same thing gave a whirrrrrrrr noise was take the wheel off and the cailper and poss the disc then turn the hub flange slowly if it rumbles over and feels notchy then its stuffed..
    I replaced mine on the last day of work before christmas break up and it took like 1 hr tops and that was stuffing round (BQQ and few beers) i admit i had a hoist and air tools but was not a overly hard job..
    But now the other side has gone so i knew i should of done both sides but repco only had one in stock and it was christmas
  1. Wheel bearings
    By Emu in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-01-2007, 01:17 PM
  2. Wheel Bearings
    By Jules86 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 27-10-2006, 09:38 PM
  3. VS Wheel Bearings & Axle Bearings
    By Harvs82 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-09-2006, 07:41 PM
  4. wheel bearings
    By ab56452001 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-01-2006, 12:13 PM
  5. wheel bearings
    By sully in forum VL Holden Commodore (1986 - 1988)
    Last Post: 13-05-2005, 07:09 PM
