Results 1 to 8 of 8
Thread: Knock/Rattle in Front Left
    VT S
    Aug 2007
    Default Knock/Rattle in Front Left
    Hi guys over the past 3 month i have had a noise which is getting more and more noticable. Seems to be coming from the Left front. It olny occurs when going over bumps turning right. Pretty hard to explain but the noise sounds like a knocking shock but ive checked it and its fine.
    Is there a common prob that you know of?
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    A common problem is worn link pin bushes. The link pins go from the struts to to the sway bar. Relatively cheap to replace if you do it yourself.
    MY RIDE
    AttaBoy is offline WTF?!?!
    VS Acclaim V6
    May 2005
    VT S
    Aug 2007
    ok im onto it tomorrow after stupid work. Thanks guys ill have a look.
    Is it pretty easy to see?
    VS Acclaim V6
    May 2005
    VT S
    Aug 2007
    ok i may need glasses it is easy to see if i knew what i was looking at. It all looks good to me. Anyone got a pic handy. One in a million im guessing
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    If you look behind the front wheels you will see the struts ( the big thing with a spring attached). On that there is a bracket with a pin about 8" long attached, the other end is attached to the sway bar or stabilizer bar, whatever you want to call it. Where the pin is attached you will see 2 rubber bushes, check them to see if they appear to be in good condition, not warped, squashed or missing completely.
    Not the best picture but you will get the idea.
    Attached Thumbnails Attached Thumbnails Knock/Rattle in Front Left-stabilizer-bar.jpg
    MY RIDE
    VT S
    Aug 2007
    your a champion. i know the one..... thank you
  1. Front Suspension Knock
    By clintonhadenham in forum VL Holden Commodore (1986 - 1988)
    Last Post: 05-08-2010, 08:01 AM
  2. Front End Knock?
    By VT Berlina 07 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-09-2007, 05:40 PM
  3. Rattle, Clunk & Knock
    By 304cci in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-01-2007, 10:12 PM
  4. Front Suspension Knock/Thud
    By Demons1964 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-05-2005, 10:09 AM
  5. vs front end knock
    By richy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-05-2004, 11:12 PM
