Results 1 to 4 of 4
Thread: rear rotor troubles??
    hinrik is offline Hinrik
    VT Commodore 5.0Lt V8
    May 2008
    Default rear rotor troubles??
    I have a 97 vt executive and have had a lot of troubles with my rotors, which isnt rare for vt's, but my rear rotors always seem to be hotter than the front rotors, i can tell by feel, and they warp alot quicker than the front. Is this Normal and if not what could be causing it??
    Thanks for your time.
    IMCRZY's Avatar
    IMCRZY is offline RESPECT!
    M6 Hazzard SV6
    Mar 2007
    Wollongong
    I had the same prob i just put x drilled and slotted monaro rotors on
    I WISH MY GRASS WAS EMO SO IT WOULD CUT ITSELF
    Tom_1569's Avatar
    Tom_1569 is offline Ecotech Power
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    Yep, we just put DBA slotter all round on the VT, done about 800k's and shes still smooth as. Theirs a whole thread on the brake shudder, down the page started by me, it has alot of information about VT shudder. thread is called "Eliminating Brake Shudder"
    Quote Originally Posted by alien View Post
    I have been hit by oil badly once while in Army uniform on a massive roundabout that doesn't exist anymore. Spun 180 degrees to face oncoming traffic.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Make sure your handbrake isn't adjusted up too much, if the shoes are in contact with the drums it will heat the rotors up. Check the condition of the calipers too, make sure the slides are free and that the pads are pulling away from the rotor when you take your foot off the brake. Easy way to tell is look at the pads, they should be worn nice and evenly and the same thickness inner and outer.
    If you require new rotors, I can hook you up with those.
    Visit my Facebook page
  1. 5L EFI - changing the distributor cap and rotor
    By savage1987 in forum Holden Commodore How-To's
    Last Post: 14-11-2008, 08:53 PM
  2. VR 5L Dizzy Rotor Removal
    By mess666 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-12-2006, 11:31 AM
  3. help need with rotor selection
    By Aryashahin in forum VY Holden Commodore (2002 - 2004)
    Last Post: 21-11-2006, 12:56 AM
  4. Which Disc Rotor
    By Bungle in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-11-2006, 07:35 PM
  5. VR Rotor Change
    By VH Vacationer in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-09-2006, 09:24 PM
