Results 1 to 8 of 8
Thread: ABS Module Removal?
    98 VT S-Pack
    Oct 2007
    Question ABS Module Removal?
    Allo All,
    Is it ok to remove the front part of the ABS module by itself and keep driving. I was thinking about sending it in to one of those repair service places.
    I removed the 6 bolts but there seems to be two little pipes(?) right underneath where it is very difficult to see/access. Also once the front part is partially off there are a lot of exposed valves/couplings. Is it safe to have them not connected while driving. (I would cover them to stop any dirt/dust getting near them).
    HELP!
    Cheers -Davo-
    98 VT S-Pack
    Oct 2007
    98 VT S-Pack
    Oct 2007
    WAIT!!, Yes me agian. That thread although large doesn't quite answer my question re driving around with half the modeule removed.
    2007 SVZ Wagon
    Aug 2007
    Murray Bridge
    1998 VT Acclaim S1
    Feb 2008
    I'm not sure what you meant by front part...if you mean the black plastic part that contains the ABS and/or Traction electronic module, then yes you can take that part out and still drive the car minus the ABS and traction.
    But if you mean taking out the ABS cylinder block itself, then I wouldn't drive the car if I were you - you would have no brakes at all.
    98 VT S-Pack
    Oct 2007
    Nope just the black electronic part.
    DR BOB: reckons not a problem.
    Cheers -Davo-
    98 VT S-Pack
    Oct 2007
    HEY All Perth locals, There is actually a local shop that reconditions ABS modules for $200
    Look up Precision (auto)electrics in Welshpool. WIll post the number soon as I find the printout I left around here somewhere
    Cheers -DM-
    1998 VT Acclaim S1
    Feb 2008
    I don't know about reconditioning electronic components...the ABS electronic module itself is encased in resin and plastic so its almost impossible to repair. I have a fair idea the problem with the older ABS module is the flimsy communication chip Bosch used during the manufacture of the modules which seems to give up over time, hence corrupting the communication line to the rest of the BCM and sometimes PCM of the car.
    By their term "reconditioning" it is most likely to be a module that has been taken from the wreckers, so chances are, it could give up again in the near future. Bosch seems to have done some work on the newer modules from the version differences noted. It will still work with your existing ABS so there is nothing different there but as a personal opinion, I'd rather pay $500 to get one new from Coventrys and have a peace of mind.
  1. How to fit an ABS MODULE to a VT
    By gumnut75 in forum General
    Last Post: 08-09-2010, 10:07 PM
  2. VN To VP DFI MODULE
    By hazza in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-10-2008, 07:07 PM
  3. module
    By lurkin308 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-12-2006, 09:17 PM
  4. module
    By ab56452001 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-02-2006, 08:16 PM
  5. Dfi Module
    By brad_m_is in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-11-2005, 05:14 PM
Tags for this Thread
