Hi Ya's,
I've been losing lights on the dash and have no tail lights on a regular basis.
Replaced the fuse and it seems to last about 2 days before it goes again.
I've checked the wiring looms and tail lights but theres nothing obvious.
Could it be the headlight switch?
It's an ex-Telstra car and the headlights are always on ...
If you've got an helpful advice i'd really appreciate it.
Thanks!
Which fuses are you replacing? Is it F4 or F11 or are you having to replace both regularly?
Thanks for the reply .... it blows fuse 4 on a two day regular basis ... had another look today since it finally stopped raining and i'm still stumped ... might have to admit defeat and take it to an autoelectrician! (shudder!!)
Thanks again.
if it is the tail light fuse check all the wires.. it could be grounding itslef and blowing the fuse
Most likely a wire rubbed through or drilled through under back seat or in boot
You don"t have a nice rusty trailer wiring socket by any chance?
