Does anyone know whether a cluster from a 5.7 can be reprogrammed to suit an exec 3.8 so that the tacho reads correctly?
there are a few options that need programming but it can all be configured with a tech2
Changing bcm to statesman will get gear selection to work though won't it?
MY RIDE
but the high series BCM wont plug into your car it would need extensive wiring mods to work
What if you had a calais?
if it is a series 1 caqlais i think a series 2 High or lux bcm will do it, ill have to check
S2 Berlina should do shouldn't it?.
Originally Posted by Yoda
