Results 1 to 3 of 3
Thread: Instrument panel/ ignition lights
    Feb 2008
    Question Instrument panel/ ignition lights
    Hi all,
    Got a problem with my VT Acclaim.
    When i start the car sometimes the ABS,Air bag, Low-Trac, Oil and engine lights all stay on
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    That often indicates a problem with the ABS module, sometimes cleaning the connector terminals fixes it for a while, if not you might need a new module.
    I seem to recall that if you disconnect the ABS module and the oil light goes out, then it is the module that's at fault. Not 100% sure on that though.
    MY RIDE
    Feb 2008
    Thanks, I will try that tomorrow
  1. digital instrument panel
    By The Darkness in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-09-2007, 10:31 PM
  2. problems seeing instrument panel
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 19-10-2006, 10:10 PM
  3. instrument panel removal/new dash lights?
    By vh-holden in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 14-07-2005, 11:51 PM
  4. Can you upgrade instrument panel?
    By AJM in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-07-2005, 10:03 AM
  5. Removing Instrument Panel.
    By Combo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-02-2004, 11:46 PM
