Results 1 to 5 of 5
Thread: 2way radio antennas
    Sep 2006
    Default 2way radio antennas
    I've got a VX and i've installed a UHF radio and i'm setting up the radio antenna. I thought front bonnet but it obscures my vision so i thought it'd mount it on the boot. When i held the antenna bracket u an L shape bracket the way the boot is designed it makes it stick out on an angle so i thought of bending the bracket in but then i can't open the boot cause it would hit. Any ideas? Mabye just mounting it to the actual boot lid instead? Cheers
    STEALTHY™'s Avatar
    STEALTHY™ is offline So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    Get a window mounted aerial. Might not have as good range, but i still got a good 20k's with my one (came with 2 sizes, that just screw on, one small mobile phone size, and one about 500mm long)
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
    BOGANV8's Avatar
    BOGANV8 is offline I gotta V8 whoot whoot
    VX 02 SS LS1
    Dec 2005
    Armidale
    The best way i have seen is your last idea i am going to do the same for my car kit antenna so when the boot goes up the antenna goes with it casue if i fit it to the boot when i open the lid the rear wing hits it being an SS has a larger wing.....
    The local 2 way place up here mounts most of the ss or ones with big wings like this..
    VX SS 5.7L M6
    Jul 2005
    W.A. Perth
    i put the uhf areal in the spot of the usual radio areal and then got a radio areal that just sticks to the back window its about 20 cm long and sits flat on the inside of the window wouldnt even know its there. the uhf areal is more important to be set up properly than a radio areal. personally i like my way no window areals neat and tidy nothing is cut up or ugly areal mount. pluss no stupid electric areal to stuff up and break 2 of mine had broken so far.
    13.3 1/4 exhaust only untuned!
    Sep 2006
    Yeah i was thinking of what "boganv8" had in mind mounting it to the boot lid. I just gotta find a bracket that is L shape in the other direction or bend one i guess.
  1. Radio PIN?
    By gyp23 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-02-2008, 08:25 PM
  2. Replies: 18
    Last Post: 06-01-2008, 07:09 PM
  3. Bullbar Mobile Phone Antennas
    By `daj0pe in forum General
    Last Post: 02-07-2006, 09:49 PM
  4. Difference between 2Way and 3way
    By Darkwander in forum Car Audio
    Last Post: 20-02-2005, 11:59 PM
