Page 1 of 2 12 LastLast
Results 1 to 25 of 35
Thread: vt versus vx -is there a difference
    vt
    Jun 2008
    Default vt versus vx -is there a difference
    hi i just bought a vt commodore has 3.8 and auto, 17inch wheels and bodykit in tundra color , i know nothing about commodores yet when my brotherinlaw lined up against my vt and i ate him! same motor and donk in both cars,
    what i have noticed on my vt though on take if i put my foot down the rear wheels break traction and really spin a heck of a lot, also the heads have been off the vt id say as there been painted chevy orange and i dont think one could get such detail without removing the heads, also this car roars when you take off hard,
    is there a differnce in power on the 2 models from factory, ??
    the previous owner new nothing about the vt as he bought it only to resell it so dosnt know what if anything has been done
    is there a way i can check to see if it has a mod chip, bigger throttle body or any other mods?
    i have noticed it has a performance exhaust on it but it aint got extractors !
    any help would be great as it would save me buying performance gear if it has it already
    were and how do i tell if it has any mods?
    V2 series 3 Monaro
    Jan 2006
    rch-13z's Avatar
    rch-13z is offline im rick james..... bitch!
    VT Exec
    Jan 2008
    South-West Sydney
    Im pretty sure the vx is slightly lighter, please correct me if i am wrong...
    But same motor, I am pretty sure the computers are different. Not sure how it effects performance...
    vt
    Jun 2008
    yeh i just found it really wierd when my vt had enormous wheel spin and still overpowered the vx,
    there has to be some mod somewere for that as i dont think factory specs alter that much
    V2 series 3 Monaro
    Jan 2006
    Quote Originally Posted by rch-13z View Post
    It depends on which series ie. 1 or 2. For example:
    VT series 1 = 1551kg
    VT series 2 = 1512kg
    VX series 1 = 1519kg
    VX series 2 = 1526kg
    All weights based on exec model. As you can see, the VT lost weight between series 1 and 2, but then the VX gained weight again.
    The above weight figures come from the brochures. Sounds weird, but I collect each model brochure when they come out. The only ones I am missing are the VB to VH series commodore. cheers.
    feg
    feg is offline
    VT S S/C
    Jul 2006
    Put it on a dyno, that will give you the answer.
    I would hazard a guess if the heads were taken off it would not be to simply paint them, perhaps a cam? Does it idle slightly rough. not sure if they idle rough with a cam anymore, maybe the computer evens it out somehow...
    Also popular mods are roller rockers and as mentioned previoulsy a chip.
    Sounds like fun enjoy!
    VE SSV UTE
    Jun 2005
    Outer North Eastern Suburbs Melb
    I have VT Calias S2 and VX Berlina S2. The VX is quieter, has more power and probably steers better due to different rear end on the S2. Overall better to drive although I do like the extras on the Calais.
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    I think you will find most of the answer lies in how well the car has been looked after over the last 10 years or so. They are starting to get on a bit now and a lack of maintenance etc will be starting to catch up with many of them.
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
    Full Spectrum's Avatar
    Full Spectrum is offline Customize your life.
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    Probably the S2 VT and VX's are closer then the VT S1 too S2 VT..
    The S1 VT were heavier and too my shock there were many things i needed to replace that a VT S1 couldn't give me, VX's did.. Fuel pumps A/C dryer receivers radiators etc more changes then you would believe.
    Quote Originally Posted by Yoda
    Do, or do not. There is no 'try'.
    <img src=http://forums.justcommodores.com.au/signaturepics/sigpic440_66.gif border=0 alt= />
    VX S2 S-Pac
    Oct 2005
    i just helped my dad put a S1 VX motor/gearbox into a S1 VT and it wont start :| some wiring was different i can say that. too look at they are almost identical.
    On a side note, what makes the noise like a pop and small backfire when starting then it dies. As in...Turn Key -> Engine Cranks over couple times -> engine pops and small back fire -> Silence (car sitting there not running :@)
    VX S S2
    Dec 2007
    Laidley, QLD
    I'll give ya a run all stock, VX series 2 S 5spd manual V6eco
    sometimes its the driver that makes the car go $hite
    oh, n turning the trac control off on the vx also helps too
    vnv8driver is offline Banned
    304 Calais
    Aug 2007
    Up your mum
    vt series 1 is slow as crap, exact same setup as vs commodore, then they upgraded a few kilowatts for series 2, vx got a little bit heavier and a few more kilowatts than the series 2 vt. vt s2 and vx should be about the same, vt s1 is slow as crap!
    benno145's Avatar
    benno145 is offline TUF38S
    VT 5sd
    Dec 2007
    Taree
    vnv8driver
    i dont now mate but i have a s1 vt and ive smoked many a vts2 + vx, and even a vs 5L and ive just got the usual mods ( exhaust etc) mine is also a manual
    STEALTHY™'s Avatar
    STEALTHY™ is offline So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    Quote Originally Posted by benno145 View Post
    vnv8driver
    haha, line up some manuals and see how you do. Anyone can beat a sludgomatic
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
  15. #15
    304 Calais
    Aug 2007
    Up your mum
    if its a s1 manual against a s2 auto then the disadvatnage cancels itself out, i cant see a stock v6 5 speed beating a healthy 5 litre even if it is auto.
  16. #16
    feg
    feg is offline
    VT S S/C
    Jul 2006
    C'mon though, back to the OPs point. if they are both stock and auto or manual vt series 1 through to vx s2 would be smoking territory. I mean it might pull away, but not like they are worlds apart.
    I agree it could be the driver. Easy way to check is switch cars. That'll soon show if someone is screwing it up.
    But realistically drivers being equal, to "smoke" the other car the thing would have to something done to it. Have a couple of runs aswell to make sure there wasn't something going on that is unforseen.
  17. #17
    304 Calais
    Aug 2007
    Up your mum
  18. #18
    IMCRZY's Avatar
    IMCRZY is offline RESPECT!
    M6 Hazzard SV6
    Mar 2007
    Wollongong
    Quote Originally Posted by vnv8driver View Post
    The VS and VT S1 are worlds apart and the set up aint the same....
    And the VT S1 & 2 have the same power
    I got a VT s1 auto and i have beat VTs VXs And VYs and even a couple of earlier 5ltrs, i have lost a few but i have won aswell
    I WISH MY GRASS WAS EMO SO IT WOULD CUT ITSELF
  19. #19
    304 Calais
    Aug 2007
    Up your mum
    thats not true the biggest part of the s2 update was the controls on the dash for the air condtioning and the 152kw upgrade over the s1's 147 which was identical to the vs s3. vy ecotec is noticebly faster than vt and vx in stock form so must of been something wrong..
  20. #20
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    My VT2 is good for 8.8 0-100 stock no weight in it other then what came with it and me, I guess that's about factory times?.
  21. #21
    304 Calais
    Aug 2007
    Up your mum
  22. #22
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    Hey that's alright that could mean it's been looked after well.
  23. #23
    304 Calais
    Aug 2007
    Up your mum
    a few mods like tune, exhaust, cai, corvette servo and diff gears will get you around the 7.0 mark.
  24. #24
    IMCRZY's Avatar
    M6 Hazzard SV6
    Mar 2007
    Wollongong
    VX was the first to go to 152 and that was to do with the flash computer and the power of the VY is the same as VX...
    And the only vs S3 was the ute
    And i have never noticed a difference inside a VT s1 & s2 and i have been in a few
  25. #25
    304 Calais
    Aug 2007
    Up your mum
    thats ok, in the series 1 like yours you would have buttons for your air con, in series 2 and onwards they have a twist knob. what mods have you got to yours and is it manual?
  1. VY versus VZ...your opinion
    By Tammy in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 11-05-2008, 06:06 PM
  2. VY V6 versus Verada GTV
    By Jazack in forum V6 Development And Modification
    Last Post: 08-01-2007, 09:34 AM
  3. V6 versus straight 6
    By vnberlwagon in forum General Discussion
    Last Post: 06-06-2006, 08:13 PM
  4. VS versus EF wagon
    By Power21 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-04-2006, 10:26 PM
  5. Vp versus ford EL
    By Tekka in forum General
    Last Post: 24-11-2005, 09:14 AM
