Results 1 to 6 of 6
Thread: Transmission line clip - What special tool is needed?
    VT LS1
    Apr 2008
    Default Transmission line clip - What special tool is needed?
    Hey guys
    Just wondering how do you undo the following transmission line (I have a VT Auto and want to do a flush). Do you need a special tool? See picture below:
    Any help much appreciated. Alternative is to undo the nut at the radiator but it is hard to get too with a open ended spanner as it does not sit flush with the nut and there is little room to move the spanner around.
    VT LS1
    Apr 2008
    Come on guys. Someone on here must be able to give me an answer or even a solution to my question.
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    that fitting is pressed on, those copper bits on the arnt screwed on are they?
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    Ado's Avatar
    Ado
    Ado is offline Are we there yet?
    vsII statesman L67
    Apr 2008
    Non removable buddy, you'll fine that if u wanted to replace that cooler line the hose and pipe will come together... y are u trying to get it off cant u just unscrew it from the radiator? or is it a jesus clip that retains it at the radiator. i cant remember on gen3
    VT LS1
    Apr 2008
    Quote Originally Posted by Ado View Post
    I was told about the line supposedly being a press fitting but I just wanted to check so thanks for that.
    I have had a look at the nut at the radiator but it is hard to get to with an open ended spanner as the radiator edges protrude out. There is also hardly turn area for the spanner at the top . Just to check as well the two transmission lines run on the drivers side of the radiator with the inlet going it at the top and the return going in at the bottom? Maybe the bottom is easiest or should you undo it from the transmission itself.
    Thanks guys
    Ado's Avatar
    Ado
    vsII statesman L67
    Apr 2008
    Just a suggestion, not sure if you've seen them u may have.... often when im doin autos radiators anything with a pipe joined to a fitting etc i use a crow's foot which u can place straight over the nut or fitting with no clearance issues then just crack with with a ratchet and extension which locks into the crows foot that would solve ur protruding edge problem u dont wanna go messin around with new pipes if u dont have to mate... GL
  1. VN Transmission return line
    By LindasBT1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-03-2007, 08:40 AM
  2. vn transmission vacuum line diagram??
    By davidb1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-12-2006, 10:13 PM
  3. Exact VE model line up, Colours, Trim options, And HSV Line up. THE GTS IS BACK!!!
    By blackahcdx in forum VE Holden Commodore (2006 - ?)
    Last Post: 11-07-2006, 10:18 PM
  4. Transmission coolers needed?
    By VXIIwagdf in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-03-2006, 05:38 PM
