Results 1 to 4 of 4
Thread: vent problem and horn problem
    Feb 2004
    Default vent problem and horn problem
    G'day All,
    It's been a while since I have been on here. Good to see still going strong.
    I have tried searching the rest of the website but can't seem to find answers to the issues with my 01 VX commodore.
    1. I keep blowing the horn fuse.
    2. I can't change the direction of air flow through vents inside the car. Turning the rotary switch (e.g. frow demist to face or feet) does not do anything. It is currently stuck on demist. There are no issues with the fan speed, A/C or temperature control.
    I only have a little understanding of mechanics but not sure where to start for either problem.
    I appreciate your time.
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Problem 1 is due to a short, most likely at the horn pad.
    Problem 2 is most probably due to a vacuum problem. Check the condition of the thin vacuum hose that goes to the rear of the intake manifold.
    If you don't hear a hiss when changing vent positions, then there is no vacuum.
    Sep 2004
    Feb 2004
    Default thanks guys!!
    Thanks guys.
    Checked the thin vacuum line at the back of the intake manifold. It wasn't even connected!!! I wouldn't have thought to look there!
    I removed the horn and replaced the fuse. When I press the horn button the fuse does not blow. So I am thinking it's the horn.
    Thanks again.
LinkBacks (?)
  1. 25-06-2008, 08:46 AM
  1. Horn problem
    By mclutterham in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-01-2007, 08:31 PM
  2. Strange VS Vent Problem..
    By Amishdan in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-12-2005, 10:15 AM
  3. VL demister vent problem
    By GH05T in forum VL Holden Commodore (1986 - 1988)
    Last Post: 02-12-2005, 10:19 PM
  4. VX horn problem
    By Harry V in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-07-2005, 09:36 PM
  5. Problem with horn
    By andy 308 in forum Electrical Wiring / Questions
    Last Post: 29-03-2005, 08:07 PM
