hey all, here is a tough one. vt has spark, has power to injectors and fuel pump is priming yet no start and plugs are dry....i get fault 46 which is a VS code, however it is a 97VT so maybe VS computer still....
any one have an idea?
Blocked fuel line..?
Run out of fuel...? Happened to me, fuel gauge said 1/4 but tank = empty =(. Still under warranty though so that was good =)
Code 46 is the same for VR-VT, crank angle reference signal (engine will not start)
Is the security light flashing when it doesn't start?
MY RIDE
hey gents, well it was the fuel pump. it was priming and doing everything it should do however a seal begins to bypass in them when they wear out and it loses pressure. 2 hours labor and a new pump $300 (not too bad) away she goes.
