hey all, i own a vu s pak ute for which i have bort a vu ss front bar with spottys..now i was told when i bort this that the spot light looms even tho there is no spottys on original bar should be tucked inside engine bay somewhere? has ne1 heard this b4?? and if so where are they hidden??? i cant find any looms anywhere to plug onto the new front bar...any help be awesome
There should be a connector or loom there for it, as they were an option for the V6 Spac.
If i remember "if" bro. my front bar is off my SS, so i will have a look where it is for ya on the car.
Simon
Yeah the loom should be up there...
I found my connectors on the bottom of the plastic radiator shroud.
Also your going to need to cut a hole in your dash fascia and get the foglight switch...
Good luck with it mate
Go to Holden and ask them for the foglight relay ($15), switch ($40), switch bezel ($3) and if you are scared to cut the dash fascia for the switch you can buy the oem fascia with a hole already optioned.
I'm abit confused, don't the S and SS share the same bumper bars? I fitted foggies to my VX S by removing the plastic inserts and bolting in the foggies.
^^^ Yeah they are exactly the same front bar...
Im assuming be bought the bar and foggies cheaper than whathe could find just the foglights for...
yeh nah the s pak front is different to the sedan one, i know the sedan had things u could pop out which were circle, but the series 2 s pak front on the ute which i took off had like off rectangle shape ones so yeh i got a black vu ss with spottys for $75 from wreckers so i was cheering...i got a switch from ute accessories in adelaide which is same as normal light switch but to engage foggys u pull button out towards u so need to cut dash or anything...its goin in tommorrow for auto electrican mate to wire up - he reckons all fog light relay is in relay box,he just needs to run a new loom from there down to the spottys...hope this works!!! and cheers to everyone who has left comments - much appreciated boys![]()
For some reason the S ute was factory fitted with the executive front bar
