Has any1 elses glove bx broken in their car, it is basically not in use because i just clipped it on and the back of the glovebox is basically hanging. Does anyone know how to fix it, mayb even a DIY job?
Cheers![]()
VX Acclaim
There should be a big round plastic pin in the glove box that has come out. It goes in the corner and it may be a bit hard getting the holes to line up.
MY RIDE
The glovebox is basically 2 pieces of plastic, the outer and inner and are screwed together around the edges. Holden sells the inner part for about $35.
All you have to do is put it together, then place it is position. The bottom left corner goes into a loop, whilst the right has the pin. Make sure you havent broken the loop off first.
Yer well its the left side thats broken, the loop, so ill have to guy nuy the inner part from holden. When i went n got my car all servicd, the idiot sed it culdnt be fixed?? haha thats why i came to the greatest website on earth
VX Acclaim
Yeah mine was broken too.Holden have em and they arnt too hard to replace.Be VERY careful fitting the glove box back in to the new loop part.Its a tight fit and mine sounded like it broke when mine popped in(crapped myself).Good luck with it.
