Page 1 of 2 12 LastLast
Results 1 to 25 of 34
Thread: taking out rear springs?
    dijm8's Avatar
    dijm8 is offline What You Looking At
    VZ SS LS3
    Jun 2006
    Default taking out rear springs?
    ey guys
    just wanna know how hard is it to change the rear springs?
    shud they just pop out when i jack the car up? can i do it with the wheels on aswell ?
    cheerz
    TWOJZ is offline Banned
    VL shagon ;)
    Apr 2008
    Adelaide!
    umm, you're going to need to take the wheels off
    and you're going to need spring compressors at the least.
    NORTI's Avatar
    NORTI is offline come get me
    VR Calais 5L, WM Statesman
    May 2004
    I did mine the other week, in the end had to losen the diff cradle & drop the whole lot down to get the springs to come out. Thats with stock springs, if they are lowereds that are in there, then prob will just drop down when you get the car up & wheels off.
    Sping compressors = dangerous! lol Ive used them on live axles no problems but damn near killed myself the other weekend when it flew off & got my shoulder
    Shounak's Avatar
    Shounak is offline The Kicking Horse
    VX Executive S2 + XF Panel Van Project
    Apr 2005
    You don't need spring compressors for the rears and it's easier with the wheels off.
    Shounak
    Always Right
    My Ride
    dijm8's Avatar
    VZ SS LS3
    Jun 2006
    yeh cheerz for that, mite just wait for when i get my tune done, then wack it on the hoist then, as hes got all the tools then, instead of doin it at home...
    yeh those spring compressors are fair dangerous as they tend to slip at any time lol
    Shounak's Avatar
    Apr 2005
    It's pretty easy and you'll probably do it within half an hour. It's the fronts that are pretty difficult to do.
    Shounak
    Always Right
    My Ride
    VL shagon ;)
    Apr 2008
    Adelaide!
    if you use a spring compressor properly, it can't slip, so I dont know what you people have been doing.
    Lumps of cheese's Avatar
    Lumps of cheese is offline Who wants chowder?
    MY08.5 VE V8 CALAIS/2010 Hilux SR D4 Dual cab 4x4
    Boulder Crusher Champion! Balloon Park Champion! Action Fish Champion! 501 Darts Champion! Frogger Champion! Jungle Kid Champion!
    Nov 2005
    Warrnambool
    Quote Originally Posted by TWOJZ View Post
    Agreed, have never had problems with them and makes job easier.
    Nov 2005
    Warrnambool
    Quote Originally Posted by Shounak View Post
    I found the front ones were pretty good to do in my old vy, the back ones were more time consuming, mabye different set up prehaps?
    dijm8's Avatar
    VZ SS LS3
    Jun 2006
    Shounak's Avatar
    Apr 2005
    dijm8's Avatar
    VZ SS LS3
    Jun 2006
    Shounak's Avatar
    Apr 2005
    Depends on what's rubbing mate, it may be possible to roll your guards, just talk to a panel beater.
    Are the sidewalls rubbing the inner guards? If it is, there's something wrong if it's doing that on Superlow's.
    Shounak
    Always Right
    My Ride
    dijm8's Avatar
    VZ SS LS3
    Jun 2006
  15. #15
    VL shagon ;)
    Apr 2008
    Adelaide!
    Quote Originally Posted by dijm8 View Post
    yeh guards were rolled when i got the 20's.... umm...adjustable panhard rod... reckon that would help.. also to keep things level
    assuming one side is rubbing the outer guard, and the other isn't, and has at least 5mm of clearance (it should have more than this if one side is only just scraping), then yeah.
  16. #16
    hakhawk's Avatar
    hakhawk is offline smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    its IRS, it has no panhard rod, so no,it wont help.
    find out where abouts it is scraping, then work from there. hopefully its scraping on the inside, then you can get a camber kit and get rid of somecamber and fix the scraping at the same time.
  17. #17
    VL shagon ;)
    Apr 2008
    Adelaide!
    Quote Originally Posted by hakhawk View Post
    ...wouldn't that mean it doesn't have a panhard rod?
    I can't answer peoples questions properly if they don't make sense!
  18. #18
    hakhawk's Avatar
    Jan 2005
    *scratches head* speak engrish man
    what doesnt make sense? he asked if a panhard rod would help, no it wont, as it does not have one.
    a camber kit might help depending where its scraping, its different to a panhard rod.
    maybe its just me, being first thing in the morning, but i dont see any confusing bits in there?
  19. #19
    VL shagon ;)
    Apr 2008
    Adelaide!
    ah, he asked if an adjustable panhard rod would help, which it would if he actually had one to replace!
  20. #20
    dijm8's Avatar
    VZ SS LS3
    Jun 2006
    y did i ask that question then..... to see if i needed 1, but obviously it dosent even have 1 which i didnt know, surely it makes sense m8, mayb go check your eyes,
    cheerz hakhawk ur good help
  21. #21
    Shounak's Avatar
    Apr 2005
    You guys are going around in bloody circles, pretty much saying the exact same thing.
    My suggestion is first jack the car up and look for any parts of the sidewall that have been scrubbed out or look for some extreme rubbing out of the tyres.
    All you need is a good trolley jack, jack it up at the diff, take it out of gear + handbrake and rotate the wheels to find it.
    After that, get a mate to observe or drive and roll the car forward to see if you can find scrapage.
    The problem with lowering a Commodore that much with such big wheels is that everything needs to become VERY precise to work. Once you find the problem, you're probably going to have to go to a suspension joint to solve it.
    Rolling the guards doesn't sound like an option. Don't get Pedders to fix it up either, they're only good for their safety check.
    Shounak
    Always Right
    My Ride
  22. #22
    dijm8's Avatar
    VZ SS LS3
    Jun 2006
    guys dont worry, its all been done, took me 10 mins not even, chuckd it up on the hoist springs fell right out, chuck new 1's in, and looking bloody sweet
    cheerz for all the ppl that helped out, look in my ride thread for photo's will be up soon
  23. #23
    VL shagon ;)
    Apr 2008
    Adelaide!
  24. #24
    dijm8's Avatar
    VZ SS LS3
    Jun 2006
  25. #25
    VL shagon ;)
    Apr 2008
    Adelaide!
    you need shorter shocks
  1. taking off speaker grills on rear shelf?
    By vxsenator in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-03-2008, 12:55 PM
  2. Taking out rear speakers?
    By Stephen_Vn_Exec in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-04-2007, 10:39 PM
  3. Wtb Vs Non Irs Rear Springs
    By biganf in forum Swap / Wanted to Buy / Trade
    Last Post: 10-01-2007, 06:04 AM
  4. rear springs for VS IRS
    By demenace in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-05-2006, 03:16 PM
  5. help with taking rear seats out
    By sik_vr_statesman in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-08-2005, 09:49 PM
