manual vx, reverse lights not working, they used to work every now n then, n now they just stopped working, have replaced the bulbs(for all who think im silly) i think it might be the sensor in the box, anyone know how hard/easy they are to replace? thanx in advance
the reverse light switches are prone for failing.... the "fix" for problem is to run a relay setup which only uses about 1 amp to power the relay instead of running 15 amps thru the switch which burns them out
if you know anything about electrics you shouldnt ahve a problem![]()
ahh cool ty, i know nothing bout setting up new electrics unfortunately![]()
hey mate, i had the same problem in my vt about a week ago, bought a new reverse light switch for the gearbox and problem solved. 50 bucks genuine but i thought that was nothing considering the original lasted nine years.
very easy to install took me about 2 minutes.
