my fan works just when i turn it up it dosen't blow any harder, it stays on one speed, do u have any ideas??
If it is only working on high speed then probably a faulty Ventilation Motor Control if you have climate control, I'm assuming you have.
MY RIDE
If its climate control it may possibly be the fan transistor/resistor, pretty easy fix piick up a second hand one for about $40-50. its located juz behind your glove box.
it does have climate control, and it onl stays on low i cant use the fan speed thing, and when the car is just sitting there it doesnt work but when i drive it stays on low...
