Results 1 to 24 of 24
Thread: SS springs??????onto std model
    1999 VT II ACCAIM & 2002 VX II S
    Apr 2008
    invercargill NZ
    Lightbulb SS springs??????onto std model
    hi guys..got offered some ss springs..my car is a std vt s2..17inch tyres..
    i'm guessing these would lower my ride a little..just looking for that sport look...
    would they be ok to just swap over or are there catches..want to do my baby up a bit..could start here..springs offered to me cheap...any help would be great..thanks.
    Noy
    Noy is offline
    VN SS 5.0
    Oct 2006
    Are they stock springs out of an ss? Im guessing there Fe2 springs, I think they lower your car like 20-30mm(I think)
    Depends how low you want to go?
    Though fe2 springs are good for handling and track use.
    Apr 2008
    invercargill NZ
    don't won't to go to low..but lower than std for sure..and yep stock ss springs..
    will they be ok or would i have to get new shocks and a camber kit???how big a job to do yourself??
    Apr 2008
    invercargill NZ
    Apr 2008
    invercargill NZ
    ok then ..while i'm waiting ..i'm goin to go paint my engine cover and brakes...
    mischa's Avatar
    mischa is offline <- 245rwkw Holden V8
    VN V6 T5 - 355 VN GRP A REP T56
    Jun 2005
    Ashbury, NSW
    since no one else with more noledgy is saying anything ill tell u wat i know. pretty sure there dif between V6 and V8, the V8 springs take more weight, also pretty sure they will physicaly fit tho just the front will be higher cause there V8 springs.
    Quote Originally Posted by keza87 View Post
    Really who wouldn't want to give Jack a good smack in the back of the head.
    The Daily VN T5V6
    355 VN GRP A REP
    chromic's Avatar
    chromic is offline Donating Member
    VT V6 Sedan, VY SS sedan
    Nov 2005
    Quote Originally Posted by mischa View Post
    I was thinking along those lines too, which was was I was a little hesitant in getting some fe2 springs off a friend who has a vy ss. (I have a vt v6) Maybe the rear springs are the same though?
    Apr 2008
    invercargill NZ
    Apr 2008
    invercargill NZ
    mischa's Avatar
    Jun 2005
    Ashbury, NSW
    rear's are the same as far as i know, because when getting part numbers the rear for V8 and V6 where the same.
    The Daily VN T5V6
    355 VN GRP A REP
    Apr 2008
    invercargill NZ
    might see if he'll split them..would save some cash..
    painted the brakes today after reading the tips on this site..came up trumps.
    going to have a go at the engine cover..could be tricky..
    ashbox's Avatar
    ashbox is offline 6 speed
    VZ SS 6 Spd
    Apr 2007
    The Car
    SS springs = fe2
    S springs = fe2
    they have the same suspension set up. The V8 only adds weight to the whole thing.
    if you want to see what your comm looks like with the springs just look for a factory height S or SS or i'm sure someone on here has an exec with fe2 springs
    Chev badges are an instant fail
    Apr 2008
    invercargill NZ
    MY10 SSV UTE
    Dec 2006
    Melb
    Default ...
    they will fit no worries, my car has got fe2 if you wanna see how they sit check out my thread in the vt/vx my ride section.
  15. #15
    mischa's Avatar
    Jun 2005
    Ashbury, NSW
    Quote Originally Posted by ashbox View Post
    SS springs = fe2
    S springs = fe2
    If the springs are identical, then why are there differnt part numbers for V8 and V6 front springs? If you where to use V8 springs the front would sit higher in a V6 then it would a V8.
    really???is this a home job or shop job??
    Depends if your up to it or not, easy job for some people, not so for other's. I think there's a how to on the site for it... I would do it at home.
    The Daily VN T5V6
    355 VN GRP A REP
  16. #16
    MY10 SSV UTE
    Dec 2006
    Melb
  17. #17
    mischa's Avatar
    Jun 2005
    Ashbury, NSW
    i wouldnt think there would be much differnce, but just pointing out there not the same.
    danteo55 I would go for it, sounds like ur getting a good deal anyway.
    The Daily VN T5V6
    355 VN GRP A REP
  18. #18
    Apr 2008
    invercargill NZ
  19. #19
    Apr 2008
    invercargill NZ
  20. #20
    Noy
    Noy is offline
    VN SS 5.0
    Oct 2006
  21. #21
    Apr 2008
    invercargill NZ
    true...but i'm new here so i'm trying to find my way around..its a big place..lol
  22. #22
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    Front springs are stiffer for the V8 over the V6 equivellant. Rears are the same. Fe-2 is slightly lower than the standard ride height.
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
  23. #23
    EvoVIIIJDM is offline Got Evo?
    Evo VIII JDM
    Nov 2005
    for the love of god lower that thing. DO you get a nose bleed from being so high?
    Quote Originally Posted by Skitz View Post
    Go ahead with the SS badges,you will reap the benefits.
    I have put SS badges and the kit on my VE Omega and when I go cruising and rev it past the girls.........well what can I say,they have drool running down their face.I chuck a U-turn and they say ''Nice car'' and I say ''It's an SS,jump in''.
  24. #24
    Apr 2008
    invercargill NZ
    Unhappy
    Quote Originally Posted by LS1Chubby View Post
    lol..i know...its awful..think i'll buy the ss springs and see what they do..
  1. Installing a Vy model strut bar on a earlier model Commodore
    By VXWAGMAN in forum Holden Commodore How-To's
    Last Post: 20-09-2009, 03:28 PM
  2. FS: Whole Suspension Setup (Springs , Shocks, Struts) King Springs
    By ssmate in forum Parts And Other Items For Sale
    Last Post: 01-11-2007, 06:24 PM
  3. Shocks/Springs, Trapped Springs, how low?
    By VNCalais98K in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-11-2006, 09:19 AM
  4. Has anybody ever swapped stock springs with SS springs?
    By vzuterus in forum General Discussion
    Last Post: 01-06-2006, 02:20 AM
  5. Swapping stock springs for SS Springs
    Last Post: 25-03-2006, 11:00 AM
