Results 1 to 8 of 8
Thread: Carbon Fibre: How is it applied? (Not what you think)
    Impulse Blue VE SV6
    Feb 2004
    Newcastle, NSW
    Default Carbon Fibre: How is it applied? (Not what you think)
    http://cgi.ebay.com.au/ws/eBayISAPI....e=STRK:MEWA:IT
    ^^^ I don't mind the look on an engine cover .. hate it on dash pieces, but looks ok there .. I was under the impression it came on a roll, like a contact type of material? If so, how is it applied to such an irregular shape as an engine cover?
    Mine is a S/C VT, so different shape to that one, but still irregular ..
    Thanks in advance
    RKZ234 Guest
    Quote Originally Posted by Lord-Data
    Thanks in advance
    In most cases it is actually a Carbon Fibre pattern on plastic adhesive sheet. (a bit like contact to protect School books)
    Genuine Carbon fibre is A.) VERY expensive and B.) made in a similar fashion to Fibre Glass.
    Impulse Blue VE SV6
    Feb 2004
    Newcastle, NSW
    Well ok, thats the stuff i'm talking about .. like i said, something like contact I'm still curious tho, how do you get it evenly and smoothly on such an irregularly shaped object?
    Bax
    Bax is offline Projecting
    Nothing
    Jan 2004
    QLD
    With a fair bit of time, not 180 dollars worth of time though.
    I'd have to see it close up, but very carefully haha.
    And yeah, carbon fibres kind of like fibreglass, except its in sheets which you place hundreds / thousands of sheets on to get the strength up, then i believe they are baked together in a pressure chamber or something.
    RKZ234 Guest
    I'd guess a hairdryer might come in handy, or maybe it is put on in a vacuum process.
    Bax
    Nothing
    Jan 2004
    QLD
    Impulse Blue VE SV6
    Feb 2004
    Newcastle, NSW
    Maybe i'll just paint it .. sounds easier .. matt black with a gloss coat should come up nicely .. i've seen some V3800 covers posted on here before (VS's i think, but same stuff) with gold lettering, think the S/C cover will come up nice too
    Camotec Guest
    Carbon Fibre comes native as a weave and is often mixed with other fibres like kevlar and graphite depending on application. it is as said before made into shapes in that way similar to fibreglass. but a few different resins can be used depending on the desired finish and flexability.
    My dad uses carbon fibre for aeroplane controls and brackets in planes that he does up.
    Ben
  1. tail lights turning off when brake applied!?!?!?!?!?
    By plAythiNG in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-10-2006, 06:36 AM
  2. carbon fibre bonnets
    By statement in forum General
    Last Post: 26-10-2005, 10:48 PM
  3. VY-VZ Carbon fibre bits anyone?
    By Phreddy in forum General
    Last Post: 21-05-2005, 10:51 AM
  4. indicators go off when break applied ??????
    By Spin in forum VL Holden Commodore (1986 - 1988)
    Last Post: 29-03-2005, 10:44 AM
  5. park lights come on when brakes applied help
    By 94 VR BT-1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-03-2005, 04:46 PM
