Results 1 to 12 of 12
Thread: inside lights
    Ve Calais V 6ltr
    Sep 2007
    ADELAIDE
    Exclamation inside lights
    hi guys just a question, my inside lights dont come on when i open the door, they will only come on when the car is on and the doors open, the lights are the door trim lights and the roof lights. it started to happen when i changed my bcm. is that the problem? thanxs scott
    VT Super6 S-PACK
    Jul 2005
    Country boy in Magil
    Hey you might have a base model bcm in a Calais?? were the numbers on the bcm the same
    Ve Calais V 6ltr
    Sep 2007
    ADELAIDE
    Quote Originally Posted by roger05 View Post
    na it was a low i removed and replaced with a high, and i forgot i dont have an immobilizer anymore i only flashes once when i lock it and before it done it twice
    VT Super6 S-PACK
    Jul 2005
    id say that is were the prob is, those bcm's had a bad solder issue. if you have a soldering iron you could go over the circuit board and re-solder all the connections in the origional bcm this some time fixes them. But prob best of trackin another low spec from some were.
    Ve Calais V 6ltr
    Sep 2007
    ADELAIDE
    where is the bcm located? thanxs for the imput
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by rvx 219 View Post
    The BCM is located up in the dash sort of above the fuse panel. It clips into place. Push the bottom of the BCM towards the front of the car to unclip it.
    MY RIDE
    Ve Calais V 6ltr
    Sep 2007
    ADELAIDE
    Red face
    Quote Originally Posted by accentstencil View Post
    thanxs m8 if i buy a new one high with a key it will all work sweet hey? thanxs for the help guys
    Ve Calais V 6ltr
    Sep 2007
    ADELAIDE
    just rang holden they said the tech 2 needs to be updated of a cost of $60 min if its straight foward? does that sound right,
    VT Super6 S-PACK
    Jul 2005
    Yeah new bcm needs to be programed to your key. $60 is nearly an hours labour that sounds a bit rough for a 10 min job, any one with a decent scan tool should be able to code it in but i don't know what the prices should be. just make sure the one you buy suits your car.
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Yes, the new BCM needs to be linked to the ECU.
    MY RIDE
    Ve Calais V 6ltr
    Sep 2007
    ADELAIDE
    thanxs guys so i will get the tech 2 chananged, i will get them to change my speedo while there coz it reads wrong due to diff upgrade
    VT Super6 S-PACK
    Jul 2005
    you can get a speedo healer from jaycar for about 40 bucks which can be changed when ever you change the diff!!
  1. V8 inside
    By ben_9876 in forum The Pub
    Last Post: 26-05-2008, 04:07 PM
  2. want to see what your amp looks like inside?
    By cxcxcxvcvcvc in forum Car Audio
    Last Post: 20-09-2007, 05:18 PM
  3. inside fan controller
    By wagonb0y in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-05-2006, 08:36 PM
  4. VT inside Door lights??
    By blunt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-01-2006, 10:48 PM
  5. Inside look at the LS2
    By vkberlina in forum General
    Last Post: 13-09-2005, 10:10 PM
