Results 1 to 4 of 4
Thread: Statesman stereo into Calais
    VT Calais V6
    Aug 2007
    Default Statesman stereo into Calais
    Just curious what the difference is between the calais stereo and the statesman stereo other than the look of it and what would be involved with installing it into a calais. I know they aren't the best stereos around and it would be better to just install an aftermarket one but I'm just curious about it and if it's worth doing.
    VX II Calais L67
    Dec 2005
    I would say it's 100% not worth doing, if anything the differences would be minor and neither stereo comes close to the range of tuning options and other advantages you get with aftermarket head units, but they do the job fine if your not worried about upgrading your sound system. It's not worth the hassle of pulling apart your old stereo to fit another stock holden one, if your not happy with the head unit in your calais just have a look at your local autobarn or jb.
    To answer your question I would assume the statesman head unit has the same plug at the back as the rest of the vt - vx range, which would make it a straight swap over. But it's definitely not worth doing.
    VT Calais V6
    Aug 2007
    I Have 2 high powered competition headunits sitting around but being the wifes and family car am not too interested in installing either of them. As I said I was curious as to what the difference is between the 2 and was planing on modifying the preouts on it to run bigger amps. Just looking at something different from the norm.
    VT Equipe
    Nov 2004
    Tullamarine
    The difference is that the Statesman unit doesn't have a clock, the clock is in the dash. You need to have the pin code to run it in the Calais.
  1. Replies: 1
    Last Post: 01-02-2007, 08:05 PM
  2. calais stereo in a berlina
    By lockmac in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-01-2007, 10:33 AM
  3. calais stereo system
    Last Post: 13-11-2006, 09:47 PM
  4. vt vx calais stereo
    By Jazack in forum Car Audio
    Last Post: 10-11-2006, 04:14 PM
  5. WH Statesman II stereo info help needed
    By veeque92 in forum Car Audio
    Last Post: 13-09-2004, 10:37 PM
