Page 1 of 2 12 LastLast
Results 1 to 25 of 46
Thread: VZ roof mount light into VT: The How Too!!
    VT Super6 S-PACK
    Jul 2005
    Country boy in Magil
    Lightbulb VZ roof mount light into VT: The How Too!!
    Righto how to install VZ style roof mount sunglass's holder into VT. A bit long winded for a simple conversion sorry.
    Tools needed: screw drivers, soldering iron, side cutters, crimpers, razor blade or sharp knife.
    Parts needed: 6x crimps, electrical tape, solder, 3x self taping screws and the light unit (about $30 from e-bay)
    Step 1: remove the roof lining, do this by taking out the sun visors, 4x jesus handles, light and all pillar trims.
    The pillar trims have clips on the back and come off with a quick hard yank, the middle one's also have a screw each.
    Step 2: Cut the hole! If you look at the roof pillar the sun visors were bolted to you will notice some extra holes
    in the middle, 2 of these shuold line up with the new light mount holes. Put the 2 self tapper screws in the holes then re-install
    the roof lining and hit it up against the srews to mark were your goin to start cutting.
    Remove the lining and place the light assembly on the back of the lining on top of the holes you just punched in it, and trace around
    the edges of the light. Now start cutting from the inside of the trace untill you have enough room to squeeze the light into the hole,
    remember don't cut around the trace because then the light won't hold the lining up and will look un-neat.
    Step 3: Now we're gettin there time for the wiring. Ive set mine up to be a slave to the origional interior light, it will come on when
    ever the origional will but also can be turned on by its self. There are different ways to do it but il show you mine and you can choose.
    You will need to run 2 wires from the old light to the new one, i used twin core double insulated wire because its easier.
    So you need to join the new red wire to the old orange wire with a black trace, and the new black to the old yellow with a blue trace on the loom in the roof.
    Now on the new light assembly cut the new plug off. Solder your red wire to the green one, your black to the blue and fianly the white goes
    to earth i used a spare hole near the mount. This is were you want to use those crimps so if you pull the light out no wire cutting needed!
    Note these wire colours suit base model calais and stato may be different im not sure, and yank the fuse before you start the wiring.
    Step 4: Ok re-fit the roof lining and light and make sure it all works and lines up, if it does re-fit all your bits and you done.
    Notes: don't use long self tappers or they will go through the roof and on the back of the new light there is a rectangle locating clip
    cut that sucker off! The hole i cut is about 20.5 by 16.5cm through the middle of the square but use this as a loose guide i think it may be a bit large.
    Attached Thumbnails Attached Thumbnails VZ roof mount light into VT: The How Too!!-1.jpg   VZ roof mount light into VT: The How Too!!-2.jpg   VZ roof mount light into VT: The How Too!!-3.jpg   VZ roof mount light into VT: The How Too!!-4.jpg   VZ roof mount light into VT: The How Too!!-5.jpg
    BANKS's Avatar
    BANKS is offline DW I'm a Spray Painter!
    VZ SSZ Ute
    Aug 2007
    Gold Coast QLD
    Did you go through the roof... lol
    Good how to, should be moved to the how to section.
    Did you already have a light there? I was thinking about doing this to the ute, but my interior lights towards the rear window
    VZ SSZ- LS1
    VT Super6 S-PACK
    Jul 2005
    Hey nah didn't go through the metal but there is one small dent were i went a lil far, il nock it back down when i feel like it. The VT only has one light in the middle, but i wanted some were to stick me goggles and extra lights can't hurt!
    Ve Calais V 6ltr
    Sep 2007
    ADELAIDE
    well i done it wow it was hard but followed the diagram no probs stuffed the roof lining cut the hole in the wrong spot but hey what another 75 for a new roof lining! lol
    VT Super6 S-PACK
    Jul 2005
    hey every one a better close up of the new light wiring in case you get stuck.
    Attached Thumbnails Attached Thumbnails VZ roof mount light into VT: The How Too!!-16.jpg
    BANKS's Avatar
    VZ SSZ Ute
    Aug 2007
    Gold Coast QLD
    Quote Originally Posted by roger05 View Post
    Whats the light blue one for?
    VZ SSZ- LS1
    VT Super6 S-PACK
    Jul 2005
    Hey banks, holden set there lights up with a permanant power and the use the bcm as an earth switch. So green always has power, blue gets earth from bcm when doors open and such and the white is earthed so when you flick the switch to on you get light.
    Full Spectrum's Avatar
    Full Spectrum is offline Customize your life.
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    Hey mate, I just got one from a VY that was self fitted by the owner, As i removed it i noticed the hole was roughly cut wasn't factory fitted, Then noticed only 2 wires needed connected to the centre light, Both power and one single wire connect from end to end.. Shocked me someone did a job like that and worked that well.
    Quote Originally Posted by Yoda
    Do, or do not. There is no 'try'.
    <img src=http://forums.justcommodores.com.au/signaturepics/sigpic440_66.gif border=0 alt= />
    VT Super6 S-PACK
    Jul 2005
    Hey Yeah some people do hell dodgy sh!t i try and do it right first time so i don't need to fix it later lol. With my wiring i just worked it out best i could but im no auto elec thats for sure
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    Same as me, Best right then Dodgy..
    I have herd there is a connector for it to connect it to the centre light? Wonder where that connector comes from holden wouldn't know or help..
    VT Super6 S-PACK
    Jul 2005
    Hey slick, dunno if there is a pre maid loom as far as i know vz's only had the front light and the rear passanger map lights maybe some one has got that loom mixed up??
    myberlina's Avatar
    myberlina is offline BAD COP! NO DOUGHNUT!!!
    2006 VE Calais
    Aug 2005
    Melbourne, VICTORIA
    I installed one of these in mine ages back and I never had to cut out the rectangular locating clip! The hole was actually there already... maybe this was applied to the VXII models in preparation for the VZ?
    Best thing to ever install I tell you what. My only problem is I keep forgetting where the sunnies are . Just not used to putting them up there.
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    Some guy on Ebay was making a fitting kit with some loom, I was going to by the whole thing light and fitting kit plug loom etc, But chicken out thinking i can't do this no way..
    And then i change half my lights to blue led and my dial face to blue, What was i such a pussy for..
    But i haven't been able to find this guy since.
    vtss series 1
    Oct 2006
    the looms are genuine holden item that come packaged with the sunnies kit but you can buy the holder alone from motorfeild pretty cheap....think about doing this convertion on the misses vt but if i stuff it up it looks like im sleeping with the dog...lol
  15. #15
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    I just did mine, Worst Case scenario happened, I cut it to much and you can see the cut on the corners, But that was the small part of bad..
    Apparently the original screws were to long?, They made dimples in the roof.
    Past that guy around the corner will fix the lining and fit the glasses holder for $160.
    But that dimple roof omg.
  16. #16
    Mc Nugget's Avatar
    Mc Nugget is offline Aka ShiZzl3
    VX II - LOWERED - 19's - HID's...!
    Jun 2008
    Melb, SE Suburbs
    i have one ready to install.
    what need to be done pre-installation.?
    do i have to remove roof lining cant i cut it while fixed?
    with wiring in my VX acclaim, is there any plug and play way of installing the wiring, i am not good with soldering / don't have equipment.
  17. #17
    VT Super6 S-PACK
    Jul 2005
    Hi every one
    slick get away you can nock those dimple's down a bit with a decent flat hammer just dont hit to hard or the dimple's will be lots bigger and goin in the other way!!!
    Shizzle you could cut the lining while its in there if your game, but if you stuff it up you'll be up for $75 for a new lining. Also ring motor traders or holden and they may be able to help with a plug and play loom
  18. #18
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    I'll give that a try mate thanks.
  19. #19
    Mc Nugget's Avatar
    Jun 2008
    Melb, SE Suburbs
  20. #20
    VT Super6 S-PACK
    Jul 2005
    shizzle its easy as to pull the lining out just a heap of phillips head srews
  21. #21
    Mc Nugget's Avatar
    Jun 2008
    Melb, SE Suburbs
    Going to attempt this tomorrow on my RDO , will have to buy parts for the wiring tho.
  22. #22
    VT Super6 S-PACK
    Jul 2005
  23. #23
    Mc Nugget's Avatar
    Jun 2008
    Melb, SE Suburbs
    yeah worked perfectly. have yet to do wiring tho.
    but the hard part is done
    find pictures in my thread
    Nuggets VXII, 19' SSV, SuperLows, Altezzas, HID's +More
    VT Super6 S-PACK
    Jul 2005
  25. #25
    Mc Nugget's Avatar
    Jun 2008
    Melb, SE Suburbs
    Default nOT HAPPY JAN
    i had this installed last week,no probems.
    Did wiring side of it today,no problems
    did everything up TIGHT .didnt think to check roof
    :'( there are to marks where the screws have pushed the metal up. im pretty sure they have almost gone through!
    IT WAS FINE LAST WEEK.MUST HAVE DONE THEM UP TOO TIGHT THIS TIME!!!!!
    What do i do? how much to fix?!!! im sooo cut and annoyed. i used a guide they said to use 25mm 6 guage metal screws and i did, now its fked.!!!!
  1. Roof mount monitor + two decks, 1 dvd 1 cd
    By Greg_Sian in forum Car Audio
    Last Post: 21-10-2009, 03:21 PM
  2. VZ roof mount sunglasses holder into VT??
    By roger05 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-06-2008, 11:16 PM
  3. changing upper mount brake light
    By paco in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-12-2006, 09:37 AM
  4. F.S: 8" Roof-Mount DVD Player & Screen
    By GLDNVL in forum Parts And Other Items For Sale
    Last Post: 21-11-2006, 10:57 PM
  5. roof mount screens
    By chevy_big_block_bro in forum Car Audio
    Last Post: 08-11-2005, 04:03 PM
