i have a '97 VT . the airbag warning light has come on out of the blue ( car has not been in accedent ) . the horn has also stoped working . could these two be related ? I have checked the fuses and reset the CPU . Id also like to know if i can "safely" remove the cover on the stearing wheel ? or will this deploy the air bag . cheers
hey mate i would not recomend taking off the cover as i have never done this but as for the airbag light could be a faulty wire have a look between the front bumper and the radiator you should see a 1 or 2 little boxes about the size of a match stick box they are the sensors for the airbags 1 could be loose or the wire ould have came off or could not be earthed out or 1 of the sensors could havepacked it in not to sure but you could try some of them lol sorry if it sounds a bit all over the place but they are a few things you could try hope it helps
Homer: "for once in my life someone is calling me sir without (your making a scene)"
the VT has no sensors near the radiator
if you remove the srs fuse you can safely remove the airbag from the steering wheel
the problem is most likely the clockspring behind the steering wheel as both the airbag & the horn wiring go through it.
lol my bad i was just goin off a few cars i have worked on
The SRS sensor box is located on top of the trans tunnel under the consul.
Pablo
MY RIDE
^^^^^^^ Yeah so does my manual was double checking to see if anything has changed...
Oh well Airbags are cheap to buy hey.![]()
hahah thats not even funny , but cheers for that ill give it a go
ok , ill do that . is there a thread on here relating to removing my steering wheel ? and what should i be looking for when checking the clockspring ? cheers
Stop looking , i found a how to thread .
