Results 1 to 4 of 4
Thread: no ignition
    VT 5.0 1998 holden ss
    Jun 2008
    Default no ignition
    Hello all I have a problem....dash lights come on and go to turn the key and nothing...does anybody know what to do in this situation...or what could it be? please help....
    Doctor Bob's Avatar
    Doctor Bob is offline Grandpa
    VT V6 Exec & VN V6 Exec
    May 2004
    Mornington Peninsula
    is the immobiliser disarming?
    the red light in the mode switch stop flashing when you turn the ignition on?
    Jun 2008
    Quote Originally Posted by Doctor Bob View Post
    no it stays on....all the lights in the dash are on...except wen I turn the key to start it all dash lights are on... but no ignition.I actually went to check the codes for diagnosis and the wire that I was useing touched something and I remember seeing a spark, it was actually after that ,that I went to start it ..there was no ignition.
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    Ouch.. I have bad feeling about what just happened. You possibly may have hurt somthing in the elctronics. Have you checked to see if you maybe (hopfully) just blew a fuse somwhere. I dont know how to overide the imobiliser in the vt's(if you can at all), but if you can and know how, i would suggest trying that. It sounds as if the imobiliser is not turning off. Does the central locking and key all work ok still. Dr bobs the wizz, it would be best to speak to him again if you can.
    Reaper
  1. Some very bad pre-ignition on VN V6
    By mike_nofx in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-02-2009, 02:29 PM
  2. vk ignition
    By nezza in forum Electrical Wiring / Questions
    Last Post: 06-02-2009, 02:27 PM
  3. help on 253 ignition pls
    By 51-EVB in forum Electrical Wiring / Questions
    Last Post: 06-02-2009, 02:25 PM
  4. Ignition problem help needed, Ignition lead fallen out??
    By boourns in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-06-2008, 05:04 PM
  5. No ignition ????????
    By v6vn/vpwagon in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-12-2006, 03:03 PM
