Results 1 to 3 of 3
Thread: Instantaneous fuel usage, idle is incorrect
    VT Executive
    Mar 2006
    se melb
    Question Instantaneous fuel usage, idle is incorrect
    have noticed something with the instantaneous fuel usage readout on the display, recently its been showing a reading of 1.0 at idle, instead of the 1.5 which i believe to be the correct value at idle, i have swapped the TPS from a mates car to see if that was the problem and it still shows 1.0, so i guess that rules out a faulty TPS, not really sure what to check next, the wiring diagram in the Haynes manual shows the coolant temp sensor wired in series with the TPS, just wondering if the coolant temp sensor is faulty can it effect the TPS?
    also the engine surges every once in a while (2-3 times a week), could the leads or plugs or coils effect the TPS too?
    changed the leads about 50000km ago
    changed the O2 sensors about 20000km ago
    changed plugs about 10000km ago
    recently cleaned out the throttle body and IACV
    recently cleaned the MAF
    coils are original i think
    error codes:-
    32 - Mass air flow sensor or circuit problem (caused by not reconnecting the sensor)
    44 - Lean exhaust
    64 - Lean exhaust
    when i cleaned out the throttle body i forgot to reconnect the MAF , thats when the engine light came on, reconnected it and reset the computer (disconnected the battery), it hasn't logged any faults since (1 week), so I'm thinking thet MAF isn't faulty, I'm going to get a new coolant temp sensor, and if that doesn't fix the problem then im stuffed as to what it could be.
    Hopefully no error codes come up, ever again, I mean EVER. Touch wood!!!
    VT Executive
    Mar 2006
    se melb
    Fixed the problem of the incorrect idle, the rubber o-ring wasn't put back on the IACV after I had cleaned it out causing a vacuum leak I guess, all good now idles at F1.5 l/h...
    VX SS 5.7L M6
    Jul 2005
    W.A. Perth
    what the correct ls1 idle value?
    13.3 1/4 exhaust only untuned!
  1. vn fuel usage
    By jimmy44 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-02-2008, 09:20 PM
  2. fuel usage
    By Simonn in forum General
    Last Post: 02-01-2008, 08:13 PM
  3. SS and SSV Fuel Usage
    By SV6Sean in forum VE Holden Commodore (2006 - ?)
    Last Post: 30-01-2007, 05:51 PM
  4. fuel usage
    By coolvxss in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-06-2006, 04:15 PM
  5. fuel usage
    By prattypkd in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-06-2005, 04:12 AM
