Results 1 to 6 of 6
Thread: The headlights in my VT suck...
    99 VT Acclaim
    May 2006
    Traralgon, Victoria
    Default The headlights in my VT suck...
    What would you recommend to replace them? The Highbeam and non-highbeam (not sure of the correct term) are pretty **** weak.
    I've got a 1999 VT Acclaim sedan.
    I'm willing to spend a bit of money on upgrading them, cause they're just stock lights
    Can you recommend something thats gonna be nice and bright. Even if I have to replace the actual light housing / lenses.
    Thankyou!
    Vp series 2
    Jun 2008
    xenon ones on ebay look allright. A couple years ago ashdown came out and showed them off using the name (gas discharge) trhey were about $1k then but you can get them on ebay way cheaper.
    PS they were DAMN bright and only 35w
    Supercharged VX S
    Nov 2006
    Quote Originally Posted by skerik View Post
    Thankyou!
    Mate try the search function on here there has been plenty of talk in the past about headlights and what different people are using.
    99 VT Acclaim
    May 2006
    Traralgon, Victoria
    Yeah I just went through the search then
    I'll probably go with the Narva ones. Might even go with the altezza fronts too maybe.
    VTII SS 5.7 A4
    Jun 2008
    Hi. I've put monaro ones in mine and they make a real difference. They should be cheap enough over there.
    Hope that helps..
    VT
    Dec 2006
    I have Philips Xtreme Power 80+ H4 globes as my main head lights and Osram Nightbreaker +90% H1's for the high beams.
    The light is bright white and a huge improvement. Also make sure your beams are adjusted correctly.
    I got mine from here: Autobulbs Direct Ltd - Xenon bulbs, car bulbs, wiper blades, headlight, Osram, Ring, Philips (they have free world wide postage)
  1. Schools suck!
    By Julie in forum The Pub
    Last Post: 15-02-2007, 04:59 PM
  2. does you life suck? want to buy a new one?
    By fluxxx in forum The Pub
    Last Post: 22-01-2007, 07:16 PM
  3. HELP HELP headlights suck
    By jacksien in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-12-2006, 10:23 AM
  4. This would have to SUCK!!
    By brownie82 in forum The Pub
    Last Post: 27-10-2006, 01:27 PM
  5. Now That Has Gotta Suck!
    By Troy711 in forum The Pub
    Last Post: 13-03-2004, 01:48 PM
