Originally Posted by
kego
hi mate,
with the auto shifter, you wont be able to use the button on top to select gears but it doesn't do anything anyway. the vy/vz shifter is to big for the shaft so you can get some tape and run the tape around it heaps to make it bigger or weld around the metal post to make it bigger so it isn't sloppy. then i just put it on and put a screw in the back to hold it on. you will see a little bit of the metal shaft under the shifter but i just got it trimmed in leather.
