Results 1 to 6 of 6
Thread: Water noise from dash, i think!
    98 VT Wagon
    Oct 2007
    Default Water noise from dash, i think!
    I have a noise that's just started from what seems to be up under the dash on the drivers side up in the top right hand corner, can't be a 100% sure that's where it is though, might be coming from the th other side of the firewall as it's tricky to find it specifically as the noise only happens when i rev the motor. The noise is the sound of running water, when the water pump speeds up i guess is when i get it.
    There is plenty of water/coolant.
    Probably will take it to Natrad i guess.
    Cheers, Darren.
    kart_racer is offline Races karts
    VT Acclaim 5M
    May 2008
    Quote Originally Posted by dazza33 View Post
    Cheers, Darren.
    I have exactly the same thing, also interested if anyone knows what it is. I've also had my drivers footwell soaked in water a couple of times and my cluster fogs up sometimes.
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Cheers, Darren.
    You might have air in the cooling system, try bleeding it.
    MY RIDE
    98 VT Wagon
    Oct 2007
    Just further to this, i checked the coolant reservoir again and it didn't have any coolant in it! Eye's must have been playing tricks on me first time around as it was bone dry! Anyway i have topped this up and the noise has all but gone. I can just still here it on occasion, maybe as i let the reservoir get so low i may have got a bit of air in her as accentstencil suggested? I will bleed it but I'm interested to know whether the low coolant level can let air into the system?
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    I think that if the level in the reservoir is low, instead of sucking the coolant back into the system it would suck air.
    MY RIDE
    98 VT Wagon
    Oct 2007
    That's what i thought as it would have to suck something through.
    Accentstencil thanks for that, your advice and opinion is highly regarded and appreciated as usual.
    Cheers, Darren
  1. water from aircon under dash centre
    By muzza in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-12-2007, 07:17 AM
  2. Water leak under dash
    By budge in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-12-2005, 06:01 PM
  3. water noise when starting
    By BobEddie in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-12-2005, 11:18 AM
  4. sound of running water behind dash
    By pd4 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-08-2005, 02:01 PM
  5. Water in sill under doors, sloshing noise
    By Gravy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-05-2005, 11:10 AM
