Results 1 to 8 of 8
Thread: Should i flush?
    CHARGEDVT is offline Veni, Vidi, Vici
    99' VTII S pack super6
    Jan 2007
    Melbourne, Australia
    Default Should i flush?
    im changing my engine oil on my super6 from magnatec to royal purple next week. just wanted to know if you guys think it wold be smart to do an engine oil flush? if so can you recommend any brand or technique to do the flush. cheers
    Shounak's Avatar
    Shounak is offline The Kicking Horse
    VX Executive S2 + XF Panel Van Project
    Apr 2005
    Waste of money.
    Just run a bit of the new oil through the engine and out the sump. You'll see it begin to clean up a bit. The so called flushes are just diesel, you can add 500ml of diesel into your engine oil to thin it out a bit if you want I guess.
    I doubt it'd do too much though. Just keep your oil regularly changed and you'll be fine.
    Shounak
    Always Right
    My Ride
    AttaBoy is offline WTF?!?!
    VS Acclaim V6
    May 2005
    Yeah as said above, no need to go out and flush it. just pour clean oil and run it until its coming out clean out the oil sump.
    2000 VX Calais 3.8L Supercharged
    Jul 2006
    is there any easy way to take off the sump and give it a clean, aswell as the oil pickup? ive head u have to take off the powersteering rack to get access to the rear bolts of the sump?
    Shounak's Avatar
    Apr 2005
    The sump only comes off if you've got a leak or something. It's not something people do on a regular basis.
    I'd have to look under my car to see, but just drop all of the bolts and you might be able to manouvre it out. If you decide to do this, I would recommend changing your sump gasket.
    The alternative to that would be to change your oil, run it with the new oil for a few days and change it again. This should ensure a lot of the sludge gets out of the system.
    Taking off the whole sump is just too much work, for seemingly nothing.
    Shounak
    Always Right
    My Ride
    pablo is offline Donating member
    Was a 1997 vt v6 wagon
    May 2006
    Chargedvt, what are you trying to achieve?
    Just drain the sump of the old oil, change the filter and pour in the new oil and away you go!
    You are not going to notice any better running of the engine by washing out the sump, if you do, it will only be a 'placebo' effect.
    Pablo
    vnv8driver is offline Banned
    304 Calais
    Aug 2007
    Up your mum
    if its not a sludged up high kilometre motor, a flush is quite a good choice, do the flush, fill up with quaility oil then add an oil additive if the valvetrain is noisy.
    Jul 2006
    my car on startup has oil pressure troubles(light flickers on once or twice a second after other lights disappear, a few people ive talked to have suggested a blocked pickup in the sump. ive already replaced oil pressure switch, only really started happening after i got the injectors reco'd
  1. Engine Oil Flush
    By fullaaa in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 10-02-2008, 01:33 PM
  2. Radiator Flush
    By brad_m_is in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-11-2007, 11:18 AM
  3. Coolant flush on VS V6?
    By Raging Bull in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-02-2007, 08:26 AM
  4. wat to flush oil with?
    By sexcvn in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-05-2006, 10:49 PM
  5. How do you flush your block
    By HDT_aero in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-02-2006, 01:04 PM
