Results 1 to 7 of 7
Thread: "quick fix" seat moulding's
    burnz's Avatar
    burnz is offline dah dut dut da dah
    2010 CRUZE Diesel
    Jun 2005
    springfield
    Default "quick fix" seat moulding's
    everybody who own's a VX know's the drama of deteching/breaking seat moulding.
    well a simple solution is where the front of the moulding seperates from the seat, the eye tab where the screw goes tend's to break, using a 1mm cord less drill.
    drilling a small hole on that remaning tounge while keeping plenty of space,
    simply insert a "carby return spring" into the hole, and streech enough to make taunt secure to a hole in frame.
    Research has shown that men usually sleep on the right side of the bed.
    Even in our sleep we happen to be right.
    Powered By Garrett
    benno145's Avatar
    benno145 is offline TUF38S
    VT 5sd
    Dec 2007
    Taree
    Thats a good idea. Both of mine broke and what i did was basically the same but i drilled a litte hole in the side of a washer and screwd it to the little plastic bit. Prob solved aswell.
    Ben
    2000 VX Calais 3.8L Supercharged
    Jul 2006
    VT97CALAIS's Avatar
    VT97CALAIS is offline VT-Best Holden shape!
    1997 S1 VT Calais /A4
    Mar 2006
    near CRANNY m8
    is this on the VT calais too?
    i've got ones with electric seat controls, and years ago my bro fixed it for my dad, as it busted off, not a 100 perfect fix but its all good. However when you lower the seats to lowest position it sometimes clunks on the plastic
    Cheers,
    VT97Calais
    burnz's Avatar
    2010 CRUZE Diesel
    Jun 2005
    springfield
    Quote Originally Posted by don0xer View Post
    pics!!!!
    when i get some bandwidth back no problem
    Quote Originally Posted by VT97CALAIS View Post
    Cheers,
    VT97Calais
    this will work for all model's
    Attached Thumbnails Attached Thumbnails "quick fix" seat moulding's-abcd0001.jpg
    Powered By Garrett
    VT97CALAIS's Avatar
    Mar 2006
    near CRANNY m8
    so basically it will bounce around cos its not fixed in tightly only just a spring that allows the side mould to move around?
    still would be better to have a rigid fix as opposed to the spring.
    but anyways good work in finding a fix!
    VT97Calais
    burnz's Avatar
    2010 CRUZE Diesel
    Jun 2005
    springfield
    VT97Calais
    as soon as i let that go it snapped back into place,
    it work's very well u can bump it, knock it, it just spring's back and doesent move.
    Powered By Garrett
  1. ""need help"" own a stocko 3800 vp and wanting to really give it some horsepower
    By boourns in forum V6 Development And Modification
    Last Post: 19-07-2008, 06:59 PM
  2. Starcorp Impul Wheels 18"x8.5" and 18"x9.5" Adelaide
    By vs_ss_matt in forum Parts And Other Items For Sale
    Last Post: 24-05-2008, 06:43 PM
  3. "VK" swapping LH front seat to RH front rails
    By VK-Berlina5.0 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 15-03-2007, 04:04 PM
  4. Is the warning "service engine oil" the same as "check oil" ?
    By morris in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 04-12-2006, 04:36 PM
  5. quick question to mods "Burnout comp"
    By commy92 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-05-2006, 06:03 PM
